Possible GPU-Z Skylake PCIe speed detection bug?
22,219 (3.44/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Memory 128GB (4x 32GB) G.Skill Flare X5 @ DDR5-4200(Running 1:1:1 w/FCLK)
Case Thermaltake Core X31
System is in specs.
So, it seems convinced I am running at PCIe 1.1 even when I run the render test. Is this really the case or is it a GPU-Z bug?
See screenshot:
good chance its actually correct
Why in the world would it lock at x16 1.1? That's like a 3.0 x4 link...
it stays this way while gaming too. Kinda disconcerting.
Windows power saving options? BIOS forcing GEN1?
Does performance feel any worse?
Yeah, I make a habit of turning all those off. I have a feeling this might be a early z170 bios bug, but I need to confirm it's not a GPU-Z bug first.
I have even set the nvidia driver to force gen3 in the registry, all to no avail
As for performance, synthetic benchmark scores have dropped but I just figured that was from the loss of my previous Haswell-E's 2 cores in a largely synthetic physics test. I'll have to try some real games real soon.
try another card/another slot? try cleaning card/slot for dust?
Don't have another PCIe 3.0 card on hand. But I know this one did PCIe 3.0 on my X99 mobo less than a week ago (yes, I go through mobos way too fast).
It COULD be the slot. I did try cleaning it for dust and such. No change. I guess I could move it to one of the slots driven by the PCH and see what it does.
try a 2.0 card and see if it locks to 1.1 as well.
Only card I will have easy access to is a GTX 780 tomorrow (via cannibalizing my brothers PC)...
Unfortunately, I'm pretty sure that's a 3.0 card in hindsight...
I'm thinking about filing a ticket with Gigabyte and seeing what they say.
Is there another tool you can use to verify that what GPU-Z is saying is in fact correct?
AIDA will display PCI-E info under Display > GPU. Mine shows 1.1 than 3.0 when running and back to 1.1 at idle just like GPU-Z.
Even if you don't own AIDA, the trial should be sufficient.
Thanks for the advice. AIDA64 trial shows the same.
Looks like yet another fun Gigabyte bios bug for me...
Last but not least, you installed the latest Intel chipset drivers, right? That's the last thing I can think of that might do it.
Early adopter woes. :(
The latest beta bios there is same as the gigabyte sites latest stable.
And yep, latest chipset drivers and all.
is there a... likely CUDA or OCL test that is known to push the limits of the bus to prove that data is being transmitted slower than it should?
I have the ASUS Z170-DELUXE running and it shows PCIe 3.0, so this is likely either a BIOS or OS power setting issue. I guess if your performance numbers aren't similar to the ones posted in my board reviews or recent DDR4 review, then something might be up, but it might also take full-screen 3D to get it to switch, perhaps.
The fullscreen 3d tests i have done refuse the switch as well.
I'll check my numbers against your reviews, thanks.
Update:
Nevermind, dumbass error in my modded bios on my part. I had set the voltage too high in fixed voltage mode, forcing the card into some kind of extreme "throttle everything" state.
My fault, nothing to see here. Move along please.
Update:
:slap:
Hey! I didn't brick my card and come crying about it! Count yourself lucky! At least I know what I'm doing well enough to fix it. :p
Seriously, thanks guys. I'm batshit insane and you should know this by now. If it isn't broken I'm not trying hard enough.
EDIT: Just realized I did doublepost though... oops. Be nice to me, mod gods.
double posts, self brickage, general nonsense.
You're fine, i'm lazy.
