Possible problem/solution to a winload.exe problem I've been having
2,331 (0.35/day)
Houston
System Name mult1kill
Processor Ryzen 7 1700X @ 3.7
Motherboard GA-AX370-GAMING 5
Cooling Cryorig H7
Memory Team Group 32gb 3200mhz
Video Card(s) RTX 2060
Storage Seagate 3TB+ Corsair 120GB SSD+120 ssd smansung 256gb m.2 Samsung 970
Case NZXT S340
Audio Device(s) Sundara JDS Labs Atom
Power Supply FSP HydroG 850W
Mouse WMO
Keyboard Ducky Shine 3
Software Windows10
Hello, it has been a great while since I've posted here. I've been having problems mainly with my pc booting up and then having to restart cause I'm getting a winload.exe error. But recently I noticed something. 1. It only happens when using windows 7, when I try using windows 10 or windows 8 it boots just fine. 2. when ever it does the winload.exe error, my sad is missing, if I restart it enough everything just boots up fine. I have no clue what it is but I feel like it could be my ssd. Having installed it on a couple of other computers lately with SSD's they don't run into any win load problems. otherwise it could be another hardware problem? either way I would like to check if maybe my sad isn't getting enough juice during boot up (would love to know how I would go about that) or just check the SSD for bad sectors, or just have one of you just determine from my explanation if it's dead or not or any other weird problems. I also only called it a possible solution because its just a matter of replacing the SSD if thats the case, it has been making the upgrade to windows 10 very frustrating, it would keep doing the win load.exe thing and windows will give up and revert back to it's original state
Thanks guys
2,331 (0.35/day)
Houston
Cooling Cryorig H7
Case NZXT S340
Mouse WMO
Software Windows10
Still not able to figure out what could be wrong with it...anyone have an idea?
Solaris17
Super Dainty Moderator
27,607 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
Grab Crystaldiskinfo ru it and see the health of your drive. Otherwise bad install or corrupt OS. you might be able to fix windows 7 with the command
Code:
 SFC /scannow
in an admin command prompt. assuming you can get it to boot. You can do an SFC off oc the disk but IDR how to target the windows drive.
2,331 (0.35/day)
Houston
Cooling Cryorig H7
Case NZXT S340
Mouse WMO
Software Windows10
Code:
 SFC /scannow
Thanks I'll give that a try right now!
2,331 (0.35/day)
Houston
Cooling Cryorig H7
Case NZXT S340
Mouse WMO
Software Windows10
So it says that everything is fine? when I know I've been having problems trying to get it to just load windows without making me restart so I don't know, Ill try the command prompt and edit this post
EDIT: I should also mention this part "You can do an SFC off oc the disk but IDR how to target the windows drive" don't know how to do that
Edit 2: "Windows Resource Protection did not find any integrity violations" .....it would be weird if its a bad os install cause it works fine on friends and I reinstalled this 3 times and it still gave me the winload.exe message
2,331 (0.35/day)
Houston
Cooling Cryorig H7
Case NZXT S340
Mouse WMO
Software Windows10
No solutions found on my end, I replaced sata cables and tried different slots on the motherboard. and different power cables as well still the same old disappearing SSD, then I would restart it and it loads up just fine. any other suggestions?
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
I've had weird issues like that. I'd suspect your hd. Sorry, but it's time for a new one. Back up your data now, order a new 3tb hd, and reinstall.
2,331 (0.35/day)
Houston
Cooling Cryorig H7
Case NZXT S340
Mouse WMO
Software Windows10
I have a 3tb HD I just want a ssd for the quick boots but it did sound like it was a ssd problem. thanks for the input! time to save for a new one
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
Keyboard Ducky
Yep, I would reinstall and check it out. I'll bet it solves you problems. I've seen where even smart drive checks would report okay, but there was an issue. Also check your psu rail voltages, make sure you are getting true 3.3v and 5v ect.
A dying Silverstone 80+ silver 850 not only took out my mobo and cpu, but mouse as well, because 5v rail was way too low. And 3.3, and 12... but you get the point. Run Aida64, check all voltages, I'm not kidding, you can lose a lot of valuable hardware if a psu goes out of spec.
2,331 (0.35/day)
Houston
Cooling Cryorig H7
Case NZXT S340
Mouse WMO
Software Windows10
Huge help from you, I grabbed a samsung 850 and so far no win load errors and no disappearing ssd. When everything is back to the desktop and what not I'll be sure to let you know how things are going with aida64. as for voltages I have always been one to use my bios and all that at default at least until my hardware could use a push when comparing to newer tech.
2,012 (0.35/day)
Heart of Eutopia!
System Name ibuytheusedstuff
Processor 5960x
Motherboard x99 sabertooth
Cooling old socket775 cooler
Memory 32 Viper
Storage raptors+ssd
Display(s) acer 120hz
Case open bench
Audio Device(s) onb
Mouse mx 518
Keyboard roccat arvo
2,331 (0.35/day)
Houston
Cooling Cryorig H7
Case NZXT S340
Mouse WMO
Software Windows10
is this corsair ssd a sandforce one?
if yes then thats your prob-some had troubles booting.
https://www.google.at/search?q=sand...-8&oe=utf-8&gws_rd=cr&ei=l0DAVbzyHYOtUaDLhbAI
i have one corsair f120 too and got troubles on z87+z97 but on x99 all is ok
RIGHT YOU ARE! Yeah it was a sandforce thats pretty weird that there are problems. maybe when I upgrade a couple of years down the line to x99 or something then Ill give it another try! thanks for the link Ill bookmark it for future references
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
Keyboard Ducky
Weird stuff, I actually suspected your older hdd.... can't really use ssds on my platform, too slow. Glad to see it's sorted out!
