power consumption : 101.58% TDP , should i worry ?
zain
4 (0.00/day)
i have gtx 1070 , i7 4th gen, 16gb ram , z97hd3 board, and corsair 750 power supply.
every game i am playing stops working after 15 to 30 min of game play , after monitoring from GPU-z i found out my gpu temperature hits max at 58 c and 70 c during gaming which is pretty normal.
but after game stops working when i switched to GPU-z it mentioned power consumption : 101.58% at max.
is this some thing to worry about ? or is my power supply to blame for game stop working ?
12,062 (2.54/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
That's perfectly fine, GPU-Z reports when a GPU increases its power consumption to hit higher boost clocks.
Looking at your system, power usage shouldn't be a problem. Fully loaded I doubt your PC uses much more than 400 Watts. I'd look elsewhere for your game crashing problems.
It could be any number of things: drivers, CPU instability, RAM instability, corrupt game files. Could be worth checking CPU temps. 70C is fine on a GPU.
511 (0.08/day)
DK
System Name Main setup
Processor i9 12900K
Motherboard Gigabyte z690 Gaming X
Cooling Water
Memory Kingston 32GB 5200@cl30
Video Card(s) Asus Tuf RTS 4090
Storage Adata SX8200 PRO 1 adn 2 TB, Samsung 960EVO, Crucial MX300 750GB Limited edition
Display(s) HP "cheapass" 34" 3440x1440
Case CM H500P Mesh
Audio Device(s) Logitech G933
Power Supply Corsair RX850i
Mouse G502
Keyboard SteelSeries Apex Pro
Software W11
No 101,58 is fine.. cards can usually go to 120% without any problems if you let them..
So it is not the reason for your crashes..
19,379 (3.46/day)
That isn't the reason for your crashes, agreed. What happens when it hits 100%+ is the clockspeeds lower. ;)
What do you mean by 'stops working'? What does that mean? Blue screen? Freeze?
zain
4 (0.00/day)
STOPS WORKING :
game hangs randomly and nothing works.. i manually press crtl+alt+del to open task manager which says (not responding) in front of the game app. and when i press win+d, there i see notification of i.e farcry 4 has stopped working or call of duty 4 has stopped working with single press button of (close progam).
Dear friend,
how can i check which hardware might be causing this ? i am using windows 7 64bit which i have refreshed multiple times to remove the doubt of corrupt Os but problem exists. plus i have tried multiple versions of graphics card driver to see if specific driver is causing problem, recently i have updated it to most recent update by nvidia for my graphics card, still problem exists.
one out of 12 crashes is caused by driver stopped responding.. it says like driver stopped and recovered , some thing like that, but its very rare.
i have tried removing the casing cover for more cooling , changing graphics card fan speed to 100% fixed too.
I have used same game files on office pc and its works fine .. so game files are ok..
511 (0.08/day)
DK
Processor i9 12900K
Cooling Water
Case CM H500P Mesh
Mouse G502
Software W11
Sounds like it is the GFX has a hardware defect,
But you can use CPU stresstest to test Cpu: Intel burnin test (but there is alot to use)
And the test in GPU-Z ( the question mark bisides the bus interface info) or Furmark for the GFX
18,584 (2.64/day)
System Name AlderLake
zain
4 (0.00/day)
Please DON'T do that!!
i have attached a picture named ImediateafterGameCrash .. i see no reason why game keeps on crashing ..
zain
4 (0.00/day)
STOPS WORKING :
2,381 (0.49/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
You guys should charge for tech support, that would put an end to the poster that trolls you in circles.
peche
Thermaltake fanboy
6,709 (1.75/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
Furmark for the GFX
are you nutz? furmark sucks... try better valley bench or futuremark...
freeze i guess.... and crash...
STOPS WORKING :
have you ever tried to unisntall and fresh install VGA drivers, in this scenario Nivida drivers and experience, and do a bench or game?
Regards,
238 (0.03/day)
Amsterdam
System Name Gamer
Processor Ryzen 7 9800X3D
Motherboard MSI MAG Tomahawk X870
Cooling Noctua NHD15-G2
Memory G.Skill Trident Z5 Neo RGB 32GB(2x16GB) 6000MHz
Video Card(s) Asus TUF RTX3080 oc
Storage Samsung 860evo, 870evo, 970evo 2x Seagate barracuda 2TB, WD Black SN850 2TB
Display(s) Asus MG278Q
Case CM Mastercase Pro 5
Power Supply Coolermaster V850 - 850Watt
Mouse Logitech Hyperion G402
Keyboard Corsair K55
Software Windows11 Pro-dual boot Windows 10
Some things to try:
make sure bios settings are correct. Especially ram timings and voltage.
Also make sure your clocks are set correctly, for cpu and gpu.
You can stress your cpu and ram with prime95, this usually does a good job in stressing your system.
There are linpack, intelburntest and aidi64 tests to stress your whole system.
Do not use furmark whomever tells you to do. It can permanently damage your videocard.
Having said that, I use furmark custom test in a 720p window with gpuz monitoring temps. It will do a short loop and show if your clocks will drop or maintain their settings. Furthermore it will show if your gpu can handle alot of stress in a short time.
However, there are much better and safer ways to test your card. A run of 3dmark can also show if there are problems.
Goodluck.
19,379 (3.46/day)
STOPS WORKING :
What do your logs say? Anything?
3,076 (0.82/day)
Do not worry about 101 %. I have modet power target in bios on my Zotac GTX 970 GPU´s from 106 to 119 % and when max overclock i have seen them hit up to 130 % and yet they live strong today even after almost 2 years of abuse. And my cards are even based on reference desing and not a after marked oc card.
In short: do not worry at all :peace:
3,505 (0.60/day)
People bricking GPU with BIOS flashing.
People ruining GPU with furmark.
Someone must be held responsible for spreading fud.
