- Mar 31, 2023
- 152 (0.19/day)
This is a speculative thread, and it might be boring it might not, so I'll get straight to the point.
The idea of building a power efficient, yet high performing PC has been on the mind lately as my power bill is getting silly and I'd like to explore this a little bit. It's easy to just say "go get a <cpu> and put it with <whatever gpu you got> and you'll be fine", but what about a scenario where you're wanting the absolute most out of some lower-power parts? Once that headline of the 9070 XT being undervolted and matching a 5080 in some scenarios it got me wondering a little bit about a build geared to do just that. Similar to the guy who shunt modded his 7900 XTX and dumpstered a 4090, though it drew identical wattage.
The general goal criteria would be as follows
I usually don't like to make speculative threads on any forum, but this one has been bugging me since I don't really see too much discussion beyond a little undervolt there a tiny overclock there or just running stock.
I have several setups that I'm considering changing in a number of ways, some with specific tasks, some with a singular very annoying task, and it's starting to annoy me how much electricity I'm drawing with my current setup, so that's the primary motivation here.
- CPU with lowest wattage with highest performance offerings (which seems to be 7600X3D at the moment? Here's hoping for a 9600X3D)
- GPU with the most undervolting and overclocking capability
- No extra power wasting (as few fans as possible, no RGB, etc)
- Making the most out of it under load is the focus, idle draw isn't really a concern
- Price doesn't necessarily need to matter but ideally lower is better
- Size constraints are not required to be anything specific, go wild
- If using a Mini PC form factor, is there a setup that can out perform a full desktop solution under the above constraints? (Oculink, eGPU of any capacity)
