Power limit problem
z3ro grvty
7 (0.01/day)
I need serious help plz regarding the power limit throttling on my Dell inspiron 15 7577 (i7 7th Gen kabylake and GTX 1050 ti)​
In old version of bios has controls of some parameters which has disabled in newer versions. I didn't know what is possible in this model for downgrade. Guide from Dell. Some ways to downgrade maybe possible but not in a home environment, but in a specialized repair shop.
Other way is settings in windows power plans.
Other way is cleaning of laptop and use if new/better thermal paste.
May combine different methods for better effect.
Hi, thanks for the reply, I did a bios downgrade from version 1.17 to 1.9 and it worked, mind you this was a custom like downgrade, where files from the 1.9 version are extracted then paired with files from the 1.17 for assembly. But hey it worked, I wonder if this is the cause of the problem.
Also tried the power plan thing, also cleaned the laptop and repasted, temps are good averaging at around 76 degrees Celsius.
But nothing helped
