Power outage happened and now PC case has static shock?
Davies
14 (0.01/day)
Power went off and on yesterday and now when i touch the PC case static discharge happens, not every single time but it wasn't happening before the outage. What can i do?
1,170 (1.66/day)
Have you started wearing differens slippers or house shoes? They may start to react differently with your carpet and you may start charging up when walking, especially in the winter when the air is dry. Connection with the power outage may be purely coincidental.
1,697 (1.04/day)
Tel Fyr
System Name 1️Purple Haze 2️Vacuum Box
Processor 1️AMD Ryzen 7 5800X3D (-30 CO) 2️Intel Xeon E3-1241 v3
Motherboard 1️MSI B450 Tomahawk Max 2️Gigabyte GA-Z87X-UD5H
Cooling 1️Dark Rock 4 Pro, P14, P12, T30 case fans 2️212 Evo & P12 PWM PST x2, Arctic P14 & P12 case fans
Memory 1️32GB Ballistix (Micron E 19nm) CL16 @3733MHz 2️32GB HyperX Beast 2400MHz (XMP)
Video Card(s) 1️6900XTXH ASRock OC Formula LM'd & Phanteks T30x3 2️5700XT Sapphire Nitro+ LM'd & Arctic P12x2
Storage 1️ADATA SX8200 Pro 1TB, Toshiba P300 3TB x2 2️Kingston A400 120GB, Fanxiang S500 Pro 256GB
Case 1️Modded MS Industrial Titan II Pro RGB 2️Heavily Modded Cooler Master Q500L
Power Supply 1️Rosewill Capstone 1000M 2️Enermax Revolution X't 730W (both with P14 fans)
Did you tried to unplug the PSU from a power line, press and hold the PC case power button until it discharges completely? Does it still persists after power on?
Few hours ago I was leaving my car in the garage, and when I stepped out and touched the metal part of the driver's door, the huge amount of static electricity drained over me. Not nice.
Davies
14 (0.01/day)
I'm not wearing anything new and yes I pressed the power button about 30 seconds with PSU unplugged, I unplugged and plugged back all the cables on the PC and the surge protector. Maybe i am overthinking it. There is nothing to worry about if the discharge is because of my clothes etc. anyways but what are we looking at if it is because of the outage?
216 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Motherboard ROG Strix Z490-H Gaming
Cooling Be Quiet Pure Rock (BK009)
Memory Kingston Fury RENEGADE KF3600C16D4/16GX (KIT 2x16)
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMe WD Black SN750 ; Samsung EVO 840 SSD and Mechanical TBs...
Display(s) iiyama Black Hawk G-Master GB2745HSU
Case CM HAF-X
Audio Device(s) Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
A wall outlet GROUND connection is a "MUST" to a PC system... This means you have no device discharge and who suffers is not you with those "static discharge's"... It's the hardware itself.
4,105 (2.61/day)
Slovenia
Processor i5-6600K
Motherboard Asus Z170A
Memory 16GB DDR4-2400
Video Card(s) IGP
Storage Samsung 850 EVO 250GB
Power Supply Seasonic G-360
Software Oldwin
If what you feel is only a momentary shock, it's static. If it persists for as long as you hold the hand on the case, it comes from the mains voltage.
Is the effect the same if you turn off the mains power switch, the one on the PSU?
Davies
14 (0.01/day)
Both wall outlet and the surge protector are grounded. It's a momentary shock. Didn't try it with PSU off I will do that.
13,949 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
If the shock is coming from you that is one thing. If the case is charged and shocking you, that's another - and not good.
How do you know the wall outlet is grounded? If case really is grounded to Earth ground through the outlet, and it is you who has the built up static charge, then no harm "should" come from this. But I would still try to get into the habit of touching something else first - besides the case or the dog's nose.
But if you have not already, you need to verify the case really is grounded to Earth ground through the outlet. Every home and every computer user should have access to a AC Outlet Tester to ensure the wall outlet is properly wired and grounded to Earth ground. I recommend one with a GFCI (ground fault circuit interrupt) indicator as it can be used to test bathroom and kitchen outlets (outlets near water) too. These testers can be found for your type and voltage outlet, foreign or domestic, (like this one for the UK, or this one for German outlets) at most home improvement stores, or even the electrical department at Wal-Mart. Use it to test all the outlets in the home and if a fault is shown, have it fixed by a qualified electrician.
229 (0.28/day)
You might have a ground fault. Ground to consumers is often connected at the transformer. Occasionally - very, but I know such situation from experience - the connection can break or be broken during a repair. The cables will then accumulate some charge. Not dangerous per se, but you lose grounding of appliances' metalwork which is not ideal.
As Bill_Bright mentioned, try an outlet tester, if it shows missing ground call your electricity provider.
Davies
14 (0.01/day)
I didn't test them and I said they are grounded because in my country, the left one is the grounded one and the right one is the one that is not grounded, I have the left one. So the theory is the outage damaged the outlet and it's causing static discharge on the case? I'll try to test the outlet or talk with an electrician. Thanks all of you for trying to help me.
3,105 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
I constantly get static discharges when i touch my PC.
Just grounding myselfbefore, then standing up and touching the case makes a visible and audible static discharge.
Davies
14 (0.01/day)
If the case was getting charged up wouldn't it shock me every time i touch it? The shockings seem random which makes me believe i am the one with the static but this thing happening after the outage is weird. I don't remember this happening before yesterday.
4,105 (2.61/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
No, you can't assume that just because you're getting static shocks. The static (electric charge) accumulates on you, not the PC, as you move and rub against synthetic or wool clothes and carpets. There's more static if the air is dry. You then feel the discharge when you touch a grounded object - the PC, the microwave oven, a water tap, a hot water radiator, the ground contact on a mains socket. It doesn't matter if the PC is on or off.
People usually assume that the car somehow collected the static while driving. But if you just immediately get back into the car and again out of the car, and the weather is dry, you'll likely get a repeated dose of electricity.
Davies
14 (0.01/day)
@Wirko I know when i rub against things it causes the discharge but it feels like it's happening more than before after the outage, that's what I'm talking about. I could be overthinking it though. I got shocked from the keyboard as well yesterday if this indicates anything.
1,697 (1.04/day)
Tel Fyr
What @Wirko said. In most cases the accumulated electricity is on the person, and discharges through other conductive surfaces. The higher capacity is (larger surface, better grounded, etc.), the effect is more pronounced. Example: A person is done with a shower, wipes the body with a towel, touches the valve, gets shocked, blames bathroom's grounding.
216 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Case CM HAF-X
From the keyboard??? Oh my god... that's bad... you or the ground connection...lol
A simple test to the PC...not to you, lol
Get this, with the system off but all plugs connected, touch a metal zone on the system tower, if it lights the ground connection is null or weak.
By the way can we know your country? Just for curiosity of AC standarts.
And another thing... having outlets with ground is one thing, if they are connected correctly that's another...
Many construction firms, would only connect WC and Kitchen outlets with ground, leaving the rest of the house unplugged from the circuit...because that was a lot of wire money saved in their pockets.
4,105 (2.61/day)
Slovenia
Processor i5-6600K
Video Card(s) IGP
Software Oldwin
Now I'm wondering what part of the world that was...
That's true but if it's meant as a diagnostic guide - how do you know who shocked whom? :wickedvioletsmiley:
2,166 (0.79/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@Tahagomizer
virtually all "old" homes in the US dont come with ground on (all) outlets,
especially if the house had "add ons" that werent properly wired.
@Wirko
if i would be asked on a game show, south/north american continent..
de.das.dude
Pro Indian Modder
9,249 (1.70/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad | Old Monke
Case Ant Esports Tempered case | Thinkpad | NZXT Guardian 921RB
Audio Device(s) Logitech Z333 | Jabra corpo stuff | Some USB speakers
Mouse Logitech G400 | nipple | Dell
VR HMD ;_;
The ground on your socket isnt functional, fix it and the static shock issue will go away.
Or have you considered that the static is being discharged from YOU to the PC? in that case try touching anything metal like a faucet, before touching your case :)
2,166 (0.79/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@de.das.dude
just because it has a ground on the outlet, doesnt mean its actually connected/wired,
so it might not be easy to fix (without an electrician coming in).
im running a dehumidifier (extremely high humidity all the time), combined with wearing rubber clogs (that insulate me),
i actually expect this, and it happens almost every time i plug something into usb.
doesnt mean i will run (regularly) into another room, just because i want to use the pc.
and unless your hw is +10y old, most boards/rigs, wont even take a hit from it (happening),
so not really an issue (hw wise)..
216 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Case CM HAF-X
You're a genius sir... never thought of that, now i know that all my school professors were doing it wrong, damm "acid's"... They didn't feel anything and now i know the reason.
They were "HIGH" as HELL
Davies
14 (0.01/day)
If something was wrong with the outlet the entire time this issue would happen before the outage, wouldn't it? The keyboards base is fully metal, so that could be from me as well. I made some movement and touched something metal and discharge happened, sure. I touch the case nothing happens I make some physical movement and touch it again and discharge happens sure but why don't I remember it happening before the outage I built this PC 8 months ago. I will do the thing @meatwar suggested, but for the outlet stuff I should call an electrician. The country is Turkey.
216 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Case CM HAF-X
The PSU could be affected... cheap ones more subjectable to it. You refer to a surge protector, not a UPS, some surge p. have fewer sensitive fuses and not break when they should... the next component will suffer from this, the PSU. But i would bet you have a weak/null ground connection.
You can also test yourself, the ground connection with a voltmeter if you have one
A quick example here: How to Check Ground Wire with a Multimeter ? - Geeky Engineers
All the best and good luck
Davies
14 (0.01/day)
Well I didn't cheap out on the PSU, it's Asus Rog Strix 650W Gold 80+. I'll try to test the outlets if I can't I can call an electrician. Is there anything else I would experience in this case other than the static? The performance seems the same. Thank you for the help.
2,166 (0.79/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@Davies
i would get an outlet tester first, cheaper than getting someone,
and its always good to (probably) know the cause, so they wont sell you on stuff that doesnt need fixing.
on the long run, try to get a UPS.
not only provides cleaner power, they tend to have a resettable fuse, so you dont need to throw out the whole strip,
and will provide power in case of brown/blackout while your using the rig, allowing to close/safely shutdown.
