Prefetch + superfetch + sysmain + ready boost + levels of cache
565 (0.24/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Motherboard MSi H110-PRO-D
Cooling LC-CC-95 @ Arctic Cooling fan
Memory 2X Crucial DDR4 2400 4GB
Video Card(s) Integrated HD 610
Storage WD 500 GB + Seagate 500 GB + Toshiba 3 TB
Display(s) Lenovo D221
Audio Device(s) Manhattan Flex BT Headphones, Encore P-801 stereo speakers
Power Supply Corsair CX450M
Mouse microsoft office mouse
Keyboard Modecom mc-800m
Benchmark Scores gorstak @ hwbot.org
Some of you may have noticed these services are missing in new windows build, and I've done some digging, so let me clarify.
What is prefetch?
Basically, prefetch is windows idea of a RAM disk. It stores frequently used stuff in a specific folder on a disk. The idea is to monitor the stuff you run often and speed them up.
What is Ready boost?
Ready boost is basically the same as prefetch, except it uses an external drive for storage, like your usb pendrive.
What is superfetch?
Superfetch is windows idea of RAM cache. It is supposed to use all available RAM for caching and try to anticipate what the user will do next. The idea is to be smart and release the used memory for caching when you run an app.
What is sysmain?
this is, amongst other things, a new name for prefetch and superfetch. It's a single service that is supposed to figure out on which kind of drive superfetch and prefetch will run. If user has an ssd, it wont run, and if user has hdd, it will. Superfetch portion of it no longer takes up all of RAM and, I'm guessing here, but I think that instead of large short term improvement in performance, they opted for small increase with time. Prefetch and superfetch registry keys are set to 3, which brings me to second part:
What DWORD values mean?
0 = zero means disabled. It wont start with pc
1 = one means automatic start. It will boot asap.
2 = two means automatic delayed start. It will start after bootup process is finished
3 = three means manual start. You start it yourself when you feel like it.
Now, who ever tells you something else, is either lying through their teeth or uneducated or an idiot!
This basically means, if you want to run superfetch and prefetch regardless of what drive you use, you set their dword values to 1.
Now let's get to caches. I have noticed recently that there is some unused caching in registry portion of windows memory management, and done some digging. I came across some articles as first google results, that should really be burried somewhere very, very deep:
What is first level cache?
first level cache is cpu cache. It speeds up cpu specific tasks. This value does not exist in my registry, meaning windows doesn't manage it. It's not enabling nor disabling it. Simply doesn't manage it.
What is second level cache?
second level cache is kernel cache. This is basically the windows core, and in my registry, managing caching of windows core is disabled, meaning bios will do it.
What is large cache?
large cache is used on workstations and servers if second level cache is enabled. It basically increases the size of RAM available to kernel and loads it all up.
What is third level cache?
This is database cache. Slowest of all caches, but shared amongst them all. It does not exist in my registry.
What is fourth level cache?
this is basically integrated gpu cache.
What is fifth level cache?
this is all other devices cache, like for example your network card. speeds up stuff like dns queries. It does not exist in my registry.
So what does all of this mean? Basically, cpu is already fast, it uses cache to speed up the rest of your system. It can use 1st level cache to speed up cpu tasks, which will show in cpu benches. Or, if the cpu has a igpu, it will use 4th level cache to speed it up. It will use 2nd level cpu to speed up your OS, and it will use 3rd level cache to help all other caches work as a unit. Basically, you can control who manages these caches, windows, bios or nobody.
That's about it. Subscribe to techpowerup and like it on social media :)
13,952 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
There is some great information above. I would like to add a little to it.
ReadyBoost uses Superfetch, but is not the same as Prefetch. Prefetch will actually re-arrange data on a hard disk so it loads faster. It is not a cache. ReadyBoost behaves more like a cache in that the data is "preloaded" into a flash drive (or similar device) much like priority data is stuffed into a page file.
Superfetch and Prefetch are two separate features. SysMain has nothing to do with Prefetch. It is, however, the new name for Superfetch. Superfetch/SysMain is a "strategic" tool - that is, it works "over time" to learn how a user uses his or her computer throughout the day to improve performance based on how that user uses the computer - to include the time of day they typically do specific tasks. Pretty cool, actually. Because it needs to see and learn a user's computing habits and daily routines in order to determine and learn how a user uses their computer, it can take a few days before it becomes most effective.
Prefetch, on the other hand, is more a "tactical" tool for "immediate" impact. It is used to optimize the loading time of an application the very next time you run it. This would be great for large applications like Microsoft Word or your security programs where multiple large files are loaded each time Word or Windows starts.
SysMain and Prefetch, while separate features, can work together. So, for example, if you regularly fire up Chrome every morning around 9 AM, SysMain, having predicted your next step will begin preloading some of Chrome's files and Prefetch will determine which files to load first once you click on Chrome's icon.
As Gorstak correctly noted, these services are automatically disabled for SSDs. That is not because SSDs are so much faster. It is simply because of how SSDs extract data. And because all SSDs report to the BIOS and, in turn, the OS that they are SSDs instead of HDs, no action is required by the user.
If you have a hard drive, there really is no reason to disable these features. Some users have reported SuperFetch/SysMain is eating up their CPU resources and to remedy that, they disable (or worse, are advised to disable :() SuperFetch. That is unwise! The problem in those rare cases is something else is causing SuperFetch to misbehave. The correct solution is to find out and fix what is causing that, rather than disabling SuperFetch/SysMain.
So my advice is to leave the settings alone! It is highly unlikely anybody on this site is smarter than the teams of highly trained and educated professional Microsoft developers with their advanced expertise in "Windows Storage Technologies", their years and years and exabytes of empirical references and evidential data, or their super computers and other tools they use to the develop the code used to dynamically optimize Windows for each user!
565 (0.24/day)
Zadar, Croatia
System Name SloMo
Processor G4560
anyway, I noticed that enabling cache management had impact on my single core cpu score. It went from 354 to 371 in cpuz with cache management enabled. My windows 10 also seemed kinda smoother with 4th level management enabled. If you intend to write that registry key yourself, don't forget to reboot prior to testing.
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
The problem there is test scores seen in benchmark programs are synthetic and often are not reflected in the same way during real-world use. I think it important to note CPU makers, motherboard/chipset makers, and OS developers have no desire to cripple the performance of our computers - with the only exceptions being to enhance security (rare) or to prevent overheating conditions (smart).
And of course, the results we see on our monitors are the culminations of the task as it has been processed through the entire computer - that is from source (disk or network), through the various motherboard circuits, RAM, CPU, the graphics solution - any and all of which affect the final results. And of course, most users perform a wide variety of tasks with their computers. That is, they don't play just one game, or just process email, or just create Word documents, or just pay their bills, or just update their Facebook page. They do all sorts of things with their computers.
So if one is going to change the defaults, (and that's fine if you really know what you are doing), my recommendation is "don't" go by test scores. Go by how the program looks and feels according to your own senses for all the tasks you normally perform on your computer. And for sure, keep an open mind and your biases at bay. As humans, it is easy to see things that are not really there when we want to see them.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Are some of these older "gimmick" technologies, that were used to optimize or give a little edge to really low end systems? Readyboost for instance. I believe they were removed due to obsolescence
44,274 (6.80/day)
Only effective on low end machines, no difference on midrange/highend
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Not sure what you mean. Readyboost is still in there.
It is not that these "gimmicks" were "removed". It is that (1), many were true gimmicks. That is a "trick" with no real or very little value. But the main reason is as eidairman1 notes, (2) they were really only useful on less powerful systems of years past. Note even budget systems today tend to have plenty of RAM and sufficient CPU and graphics speed and horsepower to meet demands, or can inexpensively upgraded to meet those demands.
44,274 (6.80/day)
Especially those Ryzen APUs
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
So they werent removed, i thought they were. Otherwise i was on the money
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Well, it should be noted they were "low-end" by today's standards - not necessarily by the standards of the day when those systems came out. For example, my first personal computer cost over $2300 and normally came with a whopping 16MB (megabyte!) of system RAM but I upgraded it to "more than I would ever need" 32MB of RAM. That was no "low-end" system at the time.
397 (0.17/day)
System Name Asus TUF Gaming FA506IU Laptop
Processor AMD Ryzen 7 4800H with Radeon Graphics
Motherboard AMD K17.6 FCH, AMD K17.6 IMC
Cooling Dual Fans Design with Self-Cleaning Cooling
Memory Samsung DRR4 - 3200Mhz 16GB(8GBx2)
Video Card(s) GeForce GTX 1660 Ti (6 GB)
Storage WDC PC SN530 SDBPNPZ-256G-1002 + SHGP31-500GM-2 + ST1000LM035-1RK172
Display(s) LM156LF-2F03 144HZ Adaptive SYNC
Audio Device(s) Realtek ALC256 @ AMD K17.6
Power Supply ASUS Power Brick 180W
Mouse ROG SICA Gaming Mouse
Benchmark Scores CineBench R23 Single core:- 1290 points CineBench R23 Multi core:- 11111 points
Thanks for providing those valuable information it is like you found a hidden treasure :D but... Could you provide how did you do it at least? :) specially the cache management on all levels... it seems interesting and I want to test it :)
565 (0.24/day)
Zadar, Croatia
System Name SloMo
Processor G4560
well, type regedit into start menu, run it, and navigate to Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management
You will find Dword key SecondLevelDataCache there with a value of 0. Change the value to 1, and create FirstLevelDataCache and then change it's value to 1, and so until you reach fifth. You can also change LargeSystemCache key value to 1, but I would advise against the latter if you only have 2GB of RAM
397 (0.17/day)
Thank you :) but I already know about 1 to 3 cache level on those registry but... I never heard before about fourth level & fifth level... so.. creating a registry of FourthLevelDataCache and FifthLevelDataCache ... are those naming is correct? :)
565 (0.24/day)
Zadar, Croatia
System Name SloMo
Processor G4560
yes, correct, but 4th level will only help if you have integrated gpu running, not discrete graphics.
397 (0.17/day)
In laptop world... Integrated GPU is always running and used :D so I'm sure there will be benefit ;) testing now and then I will report :)
565 (0.24/day)
Zadar, Croatia
System Name SloMo
Processor G4560
integrated means built into cpu...some laptops have discrete gpus aswell
have fun!
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Some do. But most use integrated because integrated tend to consume less power over all (better for battery run times) and a single processor tends to generate less heat - always a concerning factor with notebooks. And then there is motherboard real estate and weight factors too. Since, by far, most notebooks are used as mobile devices for personal business, work or school, that all makes sense.
22,181 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Where are you finding these registry keys?
As far as I can tell, the keys above second level are undocumented and likely do nothing at all. The only reference to "FourthLevelDataCache" I can find for example is a fake key mocking the idea that it will work... in french:
https://translate.googleusercontent...700248&usg=ALkJrhhUv0-fuDtpBY8_OyKLTrqnUFAeug
The other keys don't do anything unless you are running a Pentium Pro or something ancient.
Sorry but unless I ses docs from microsoft those keys are just snake oil... minus the oil, even.
Also, the idea that windows can even "manage" cache at all (it can't, that's not how cache works. it can only structure memory to work better with really strange kinds of it) is a misunderstanding of the difference between "cache" and "memory" and really how things work.
2,707 (0.72/day)
On The Highway To Hell \m/
Which you attribute to having first level "CPU cache management" enabled I presume? It's odd that you say that. Yet don't provide any "proof" of it. So allow me...
3 tests were performed with each configuration. Highest score recorded for each.
No first level data cache "management" enabled.
With first level data cache "management" enabled.
...those keys are just snake oil...
Dammit! You just stole my line!
100% PURE UNADULTERATED SNAKE OIL!!!
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Kinda, sorta, but not really. You really need to be very specific here because it all depends on what kinda cache you are talking about. The page file, for example is a cache and the OS manages that both in terms of size and what data is stuffed into it.
The buffer on a hard drive is a cache - but the OS does not really have much to do with that. And the cache built into CPUs is generally managed by the CPU (with help from the chipset (I think!)) itself.
In any case, regardless which cache you are talking about, unless you are a true expert in computer architecture and memory management, it typically is best to just let the real experts manage it and stick with the defaults set by the CPU makers, chipset makers, drive makers and OS developers. That's there job after all and they have "teams" of experts developing these protocols and very deep pockets to crunch the data, review the history and set up and run the test facilities to make sure they do it right. It is highly unlikely anybody here has such a unique scenario that they need to deviate from the defaults - or the knowledge to do it right under the dynamic (ever changing) demands of today's computing tasks.
565 (0.24/day)
Zadar, Croatia
System Name SloMo
Processor G4560
correct again bill...someone hires people for work, and someone hires a manager too
22,181 (3.43/day)
Olympia, WA
System Name Pioneer
on-die main memory caching was my line of thought, but thanks for clarifying.
565 (0.24/day)
Zadar, Croatia
System Name SloMo
Processor G4560
Anyway, I made a simple reg key with a few other speedup windows tweaks, so you just need to import it into your registry and restart your pc
This is, of course, completely optional, and at your own risk.
  • speedup.zip
13,952 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Has that hack been tested on Windows 7, Windows 8 and Windows 10? Both 32-bit and 64-bit? I feel if a user does not know if the changes this hack makes will work with their version of Windows, they probably should not be dinking around with the Registry.
While I appreciate the desire to improve the performance of users' computers, and the work that went into developing that hack, I feel we, as advisors, would be remiss not to point out the dangers of dinking around inside the Registry. It is easy but a huge mistake to assume all TPU readers are advanced and experienced users. Everybody was a newbie once, and new newbies are coming on line every day. And just because a user may be highly advanced, very experienced and even a recognized expert in some areas within IT, that does not make them a Windows or Registry expert.
There is a reason Microsoft does not make calling up the Registry Editor or making changes to the Registry as simple as starting File Explorer or calling up Edge. Editing the Registry is dangerous. One simple typo and you may brick your computer. I feel simply warning to use at one's own risk is like telling a little kid to cross a busy highway at their own risk, then washing our hands of any responsibility.
  • Changes made to the Registry are done in real-time! That is, the changes are done immediately and often don't even need a reboot to take effect.
  • There is no confirmation process. That is, Windows does not prompt users with an "Are you sure?" warning before changes take effect.
  • There is no "undo" feature. So if you mean to change 11e1 to 11d1 and accidentally enter 11f1, the change is made! If you don't remember the original value, or what you meant to enter, it could be brick time.
  • There are no prompts or warnings to backup the Registry before making any changes!
  • There are no automatic backups as Microsoft Word does by default.
  • Regedit does not even have a backup or restore feature. Only Export and Import and those features are not explained or very intuitive.
If you don't know how to backup your Registry, you probably should not be dinking around inside the Registry.
If you don't know how to restore from a Registry backup (especially if your computer will not boot), you probably should not be dinking around inside the Registry.
With all that in mind, use at your own risk.
397 (0.17/day)
What about modding your BIOS? I am living between success and bricked laptop... like nearly everyday because I always try new things and tinkering with my BIOS... it is fun!! :D Thanks to SPI BIOS Programmer... I revive my laptop (it is on my signature) for nearly everyday ;) so... registry things are really nothing at all to me but for others... yea sure :)
All what I am trying to say that... people who know what they are doing are the ones who likes to try while he/she knows the risks but those who don't... just... save your time and all the others time and just skip the whole thing while you can !
