[PROBLEM] 4850 Bios pin mod (After Change Device ID, not recognized by atiflash)
reny28
9 (0.00/day)
hello,
I have a ATI 4850 512MB (21132-00-20R)
I can not find that I have to reset the bios chip, I changed DeviceID with RBE (4850 to 6850) and now is no longer recognized, even by atiflash ...
where is the chip? chip found
I posted a guide (link) on how to do it?
thanks
ps: I log on Windows, but there are no drivers ("no data available")!
I need to know how to proceed
2,318 (0.33/day)
System Name MONEY PIT
Processor i7-3770K @ 4800 1.20v batch #3231B415 Delided
Motherboard ASrock Z77 OC Formula w onboard waterblocks
Cooling Apogee HD, MCP655,rad MCR320-XP,Micro Rev2 res
Memory G,skill Trident X F3-2400C10D-16GTX
Video Card(s) EVGA GTX 980 Ti Classified with EK nickel/acetal waterblock installed
Storage 2x120gig Wildfire raid0 2x120gig VERTEX3 raid0
Display(s) 3/ Samsung2343bwx + 65in LG 4K
Case NZXT Phantom White w/red
Audio Device(s) ReCon3d fatal1ty pro, Logitech z906 THX
Power Supply corsair AX860i
Mouse Rat7
Software 64bit ++++ win 10
reny28
9 (0.00/day)
thank you for your reply, I tried to short-circuit 1 and 8, 1 and 4, and finally 4 and 8 (VCC and GND)
finally recognized the card but:
-does not make me start Windows (some beeps at startup). then within the video card Integrated (G31M-GS)
-I can not flash anything on the bios, Write Fail: error 0FL01
thanks
W1zzard
Administrator
28,620 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
you pull chip enable high, so the chip is disabled. this should let you boot.
once you are at the dos prompt you need to pull it low (while the system is running), so the rom chip gets enabled and can be flashed.
now start the flasher, it should flash.
reboot, you can leave chip enable as is, the card should work fine
dont connect gnd and vcc together as that will cause a short circuit
reny28
9 (0.00/day)
I'm sorry but they are not very practical!
I do not quite clear which pins should I connect, you may watch the immaggine and tell me which pins should I connect?
I have to start with the integrated? or with PCI?
when I have to disconnect the wires?
to activate the chip ROM, I have to run the command <atiflash -unlockrom 0>?
thanks, I really appreciate your help
EDIT:
Pins 1 and 8 connected (CE # and VCC) (see immaggine):
atiflash -f/-fa/-fm/-fs/-fp -p 0 ati.rom/rv770.bin
Write fail
Error 0FL01 ...
TEST ROM:
atiflash -t 0
PASS
Deleted member 24505
EDIT:
Write fail
Error 0FL01 ...
TEST ROM:
atiflash -t 0
PASS
1. connect pins 1 and 8 leave them connected
2. boot up on integrated graphics
3. once it boots up to the dos prompt, disconnect the connection from pin 1 and 8
4. now start the flasher, it should flash
W1zzard
Administrator
28,620 (3.74/day)
Memory 48 GB
you probably need to connect 1 and 4 at that point to pull the input low, unless it has its own pulldown resistor
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
unfortunately does not go ...
"write fail error ..."
the chip is damaged?
No/Maybe
Write fail Error 0FL01 ... TEST ROM: atiflash -t 0
PASS This command line is wrong or the vbios is the wrong one
Manufacturers Name? and Model of the vga card [add link to card], please
If booting using onboard Igp/vga intagrated in CPU or onboard vga = 0 [Zero] (atiflash has this error as it attempting to write to the) integrated graphics
HD 4850 vga card = 1
Type at the dos prompt: atiflash -ai 1 [see if the HD 4850 is recognised]
Type at the dos prompt: atiflash -t 1 [see if the HD 4850 vbios passes]
*If HD 4850 vga card is recognised
Type at the dos prompt: atiflash -f -p 1 [#BiosName#].ROM
atb
Law-II
reny28
9 (0.00/day)
Hi
No/Maybe
Type at the dos prompt: atiflash -f -p 1 [#BiosName#].bin
atb
Law-II
hi, i have ATI 4850 512MB (21132-00-20R)
I'm using onboard vga of G31M-GS
I tried atiflash -i/-ai 1 "adapter not found"
I tried to remove the 4850 from the PCI slot, and I gave the command from DOS atiflash -i/-ai 0/1 "adapter not found"
thanks:respect:
reny28
9 (0.00/day)
try...
edit:
write fail error...the same as before
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
thanks Thanks for the info
Try this vbios image - http://www.techpowerup.com/vgabios/16834/sapphire-hd4850-512-080602.html
I tried to remove the 4850 from the PCI slot, and I gave the command from DOS atiflash -i/-ai 0/1 "adapter not found" Card should be installed during this process; *do not remove card
Onboard vga is selected in motherboard bios as primary device?
Read Here
With Pin 1 & 8 connected to vga card's vbios and card installed to PCIe Slot adapter is found at 0 [zero] left wire attached to pin 1 & 8 ran command atiflash -ai at position 0 or 1 at dos prompt [adapter found? at 0] cut wire and flashed vga card atiflash -f -p 0 #Bios Name#.ROM
[when booting from onboard vga card is at 0 zero? odd]
Motherboard is this
atb
Law-II
reny28
9 (0.00/day)
Hi
Try this vbios image - http://www.techpowerup.com/vgabios/16834/sapphire-hd4850-512-080602.html I've already tried, tried both with this and with the original backup
Onboard vga is selected in motherboard bios as primary device? Yes
Read Here already read a couple of times :)
Motherboard is this yes
atb
Law-II
as i wrote before, when i remove the VGA (PC turned off, normally) from the PCI slot, Atiflash with the commands "atiflash-i 0/1" does not detect any card
I turn off the PC and get back the card into the PCI slot, boot from the onboard VGA, and with the command "atiflash-0".. atiflash detect the card
i turn off the computer and connect pins 1 and 8 and once in DOS, cut the wires and try but always gives me that damn error: ERROR WRITE FAIL 0FL01
I think I burned the bios of the card, since I had also attacked VCC to GND (knowing full well what I was doing) :banghead:
thanks
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
Indeed that may have damaged the vrom; sorry to hear of your loss
atb
Law-II
reny28
9 (0.00/day)
Hi
atb
Law-II
thanks for the help
one last thing, if I replace the bios chip PM25LV512 with an identical one ($ 2.70) could solve? I am very good with the soldering
and if I take the bios of a sapphire ati x1600 and install it on the 4850? I do not know much about bios but I understand that it is similar to a ROM, you just flashing in the right data
2,318 (0.33/day)
Mouse Rat7
2,318 (0.33/day)
Mouse Rat7
but I wanted to know if I can recover from a x1600 chip, solder it on the 4850 and flash the rom of 4850
YES you will have to use the 8--to--1 pin mod to do the reprogram on the chip
If you put the x1600 ROM chip on your card, you would treat it just as if you had flashed the wrong bios.
