Problem closing CPU socket cover on new motherboard, would love some HELP??!!
60 (0.01/day)
Bournemouth
Processor i5-3570k
Motherboard GIGABYTE GA-Z77X-UD5H-WB
Cooling Be Quiet Dark Rock PRO BK016
Memory Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz
Storage Force Series 3 120GB SSD, WD 3TB HDD
Case Fractal Design Define XL USB3.0 Full Tower Case - Black Pearl
Power Supply Corsair HX750W
Software Windows 7 64bit
I am a first time builder and i have a Gigabyte GA-Z77X-UD5H motherboard and a Intel i5-3570K CPU.
I fitted the CPU into the slot perfectly but when it comes to fitting the bracket which holds it into place over it and pulling the lever down to lock it into place it seems to put alot of pressure onto the CPU in fact i only got the leaver down half way before i heard a scrunching sound. I immediately stopped as was always told now pressure should be put on the motherboard or CPU. I checked with a video on you tube for the build of my motherboard and the guy says his is stiff as well and feels like your going o break it when you lock it into place but do i take that risk i just spent nearly 400 pounds.
Would love some suggestions on the matter, thanks in advance!!!!!
Leon
brandonwh64
19,542 (3.42/day)
as long as its lined up with the socket notches then you should be fine. It does feel like a lot of pressure but it has to seat the CPU into the socket and pins.
60 (0.01/day)
Bournemouth
Processor i5-3570k
thanks man will go for it ;)
1,683 (0.32/day)
State College, PA, US
System Name My Surround PC
Processor AMD Ryzen 9 7950X3D
Motherboard ASUS STRIX X670E-F
Cooling Swiftech MCP35X / EK Quantum CPU / Alphacool GPU / XSPC 480mm w/ Corsair Fans
Memory 96GB (2 x 48 GB) G.Skill DDR5-6000 CL30
Video Card(s) MSI NVIDIA GeForce RTX 4090 Suprim X 24GB
Storage WD SN850 2TB, Samsung PM981a 1TB, 4 x 4TB + 1 x 10TB HGST NAS HDD for Windows Storage Spaces
Display(s) 2 x Viotek GFI27QXA 27" 4K 120Hz + LG UH850 4K 60Hz + HMD
Case NZXT Source 530
Audio Device(s) Sony MDR-7506 / Logitech Z-5500 5.1
Power Supply Corsair RM1000x 1 kW
Mouse Patriot Viper V560
VR HMD HP Reverb G2
Software Windows 11 Pro x64
Benchmark Scores Mellanox ConnectX-3 10 Gb/s Fiber Network Card
That sound and pressure is normal for LGA1155. It's much more than LGA1366 or LGA775 - I had to get used to it at first too. Just make sure the notches are lined up as brandonwh64 said and you should be OK.
9,019 (1.38/day)
System Name Black Panther
Processor i9 9900k
Motherboard Gigabyte Z390 AORUS PRO Wifi 1.0
Cooling NZXT Kraken X72 360mm
Memory 2 x 8GB Corsair Vengeance RGB Pro DDR4 3600Mhz
Video Card(s) Palit RTX2080 Ti Dual 11GB DDR6
Storage Samsung EVO 970 500GB SSD M.2 & 2TB Seagate Barracuda 7200rpm
Display(s) 32'' Gigabyte G32QC 2560x1440 165Hz
Case NZXT H710i Black
Audio Device(s) Razer Electra V2 & Z5500 Speakers
Power Supply Seasonic Focus GX-850 Gold 80+
Mouse Some Corsair lost the box forgot the model
Keyboard Motospeed
See that little arrow bottom right? As far as I know there'd be a corresponding arrow on the motherboard. Just make sure the cpu not only fits perfectly (the pins are arranged so that it can only fit in one position) but also that it is all the way down into the motherboard.
132 (0.03/day)
lol when i build my PC... i'll be "OMFG" if i hear a crunch sound or i'd be nervous if i had to use more force..
60 (0.01/day)
Bournemouth
Processor i5-3570k
Haha well I did it and it felt like I was going to break it but I read up and apparently other people have had the same problem with the motherboard :/
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
This is one of those things you have to experience to know. Just like locking down a memory stick, stock Intel CPU fan or CPU retainer. They all sound like its breaking something and the board does bend. Just support it where you can, make sure its in the right way and go for it
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
The CPU will fit into the socket one way best, the arrow (key) points to the corner of the socket with the matching arrow (key). It takes a good amount of pressure to lock the CPU down and into place, and keep in mind that as you're essentually pushing the CPU down (since this is LGA, not PGA like AMD processors sans C32 and G32,) the CPU will be pushing on the sockets pins into the board unlike PGA where the socket clamps down on the pins.
leedonald54
4 (0.00/day)
You will lurn fast ,as i have some verry hard ones , I have a small flat screwdriver that I use .I build moteley AMD ,but have done several INTEL,s .THEY are using AMD sofware to hook threr 32 to gather, not commany nolage ,I having been buliding sence 1999.
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
I can't say I understand any of that. Welcome to TPU by the way.
922 (0.16/day)
London, UK
Processor AMD FX 8350 Black Edition @ 4.2Ghz
Motherboard Gigabyte 990FXA-UD3 Rev 4.0
Cooling Corsair H100i
Memory Samsung Green 16GB 30nm 1600Mhz DDR3
Video Card(s) XFX HD 7950 DD 3GB @ 850/5000Mhz
Storage 240GB Intel 520 SSD + 2TB Seagate Barracuda
Display(s) ASUS PB278Q 27" QHD
Case Fractal Design R5 Black
Power Supply Seasonic Platinum 760W
Mouse Corsair Raptor M40
Keyboard Corsair Raptor K50
9,923 (1.80/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
or you could try to close it without processor first, if its ok put back the processor and make sure the processor seats right
