Baroraj158
- Dec 24, 2022
- 2 (0.00/day)
Hellou im fresh in this forum, i. Have problem with my build pc all hardware specs : mbu msi b450 pro vdh plus (newest bios flashed) / msi A320M Pro Vh Plus same post stuck on vga flash
CPU Ryzen 5 2600X
Ram Aegis 2x8 gb 3200mhz
GPU 3060TI z gaming trio/ 2060ti ventus trio
Hdd Nvme Kinstong m.2 500gb(not installed component)
Power supply Xilence xp700r6 700w ( didn't see holding up state efficiency 550w)
So now i can explain whats the problem .
First time i got this same problem I build this pc first time got post installed Os en all thinks worked perfect until i flashed newest bios en upgraded to win 11 restarted pc en got back in win 11 windows update check for updates, got updates installed en asked for restart after restart no video outpout, motherboard process ez debuger cpu flash then restart cpu flash en stuck on VGA
I solved the problem but still don't know how i tried cmos reset jbait , dissembling everything from case differenct cpu different gpu en using one ram ( changed all 4 slots) the first time i solved it butt now after 2 weeks my 3060 ti needed new cooling pasta en now the same trouble but nothing helps
( i think it should be my power supply i bough him brand new butt when was working good en was gaming 120hz got from psu noise exact same like wiring coil , when my gpu consumption was low got no noise when was used on max got loud sound like wiring coil or bed old hdd scratching)
Or should be it that my new bios 7A38v9E is switching my mbu to integrated gpu? ( didn't try cpu with apu becaus don't have one)
Post process
CPU Ryzen 5 2600X
Post process
