Problem installing XP - Please Help!
Peteballaghaderreen
61 (0.01/day)
Processor Core 2 Quad 8300
Memory 8 GB
Video Card(s) Geforce 210 512MB
Storage 750 GB (internal) 640 GB (external)
Display(s) Philips 230C1HSB 23" Full HD
Audio Device(s) Asus Xonar D2PM High Def
Power Supply 330W
Software windows 7 home premium
I built a PC, and installed Windows Vista on it.
After a while, I got sick of Vista, and wanted to go back to XP. I bought a genuine OEM copy of Windows XP Professional, and made a partition on my hard drive to install XP on it, as I thought Vista will be useful to still have in years to come. So I created this partition using Disk Management in Vista.
I put in the XP Pro disk. It asked me where would I like to install it, so I said D:, the partition I had created. So it formated it NTFS, copied files to installation folders, then it said Saving Configuration . . . . .Restarting Computer . . . . and it restarted. Then when it rebooted from the CD it started the whole process over again. I can't get past this step,even though I have tried loads of times. What's going on?? I tried to boot from hard disk, but it just said "Error loading Operating System"
Any help much appreciated
4,413 (0.65/day)
Processor Intel Core i7-7700K
Motherboard ASUS ROG Strix Z270E Gaming
Cooling Arctic Cooling Freezer i11
Memory 4x 8GB DDR4 Corsair Vengeance LPX @ 2133MHz
Video Card(s) 2x NVIDIA GTX 1080 Ti FEs
Storage 512GB SSD, 2x2TB HDD
Display(s) AOC U2879VF, AOC G2260VWQ6
Case Corsair 750D Airflow Edition
Power Supply EVGA Supernova 850G
Software Windows 10 x64 Pro
Run once through the disk cycle, then don't press a key to boot from CD. It needs to boot from HDD on it's own, just make sure the BIOS is set to boot from HDD second or third.
Solaris17
Super Dainty Moderator
27,605 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
hmmm thats odd you should have atleast gotten a os selection menu....try booting the xp cd go into repair mode and do the follwiong commands...
fixboot
fixmbr
Peteballaghaderreen
61 (0.01/day)
Memory 8 GB
Power Supply 330W
Thanks for the quick responses.
I tried to boot from HD, but it said error loading operating system. Is it a problem with my hard drive? Should I delete Vista from C: Partition 1 first or would that make any difference?
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
sounds like it really screwed up your boot loader....try the methods i suggested above or run this command...chkdsk /r
Athlon2K15
HyperVtX™
7,909 (1.16/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Cooling Custom Water
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
when dual booting u have to install xp first then vista
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
2nd you should also make it diff disks becuase most of the time youll get like an ntdlr error or something they dont play well on the smae disk case in point..iv learned the hard way to many times
Peteballaghaderreen
61 (0.01/day)
Memory 8 GB
Power Supply 330W
I'm trying to completely format the entire hard drive, partition C: and D:. I can delete D okay, and it now says unpartitioned space. C: is a bit harder. I tried to format using the Recovery Console, but it needed an admin password. I never set up such a password so I don't know what it is. I'm trying now to delete partition C: from Windows setup. It says the following message
The partition you tried to delete is a system partition.
System partitions may contain diagnostic or hardware configuration programs, programs to start operating systems or other manufacturer-supplied programs.
Delete a system partition only if you are sure that it contains no such programs or if you are willing to lose them. Deleting a system partition may prevent your computer from starting from the hard disk until you complete installation of Windows XP.
What should i do? I think only Vista is installed on the Hard Drive, i don't mind losing that. Will it delete anything vital? I just want the hard drive completely formatted so i can install XP Pro.
Thanks in advance
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
no go ahead and format it nothing bad will happen....and if it wont do it...iv got a link to a really good format prog you can use that will kill any hdd down to the bare min. its called deriks boot and nuke
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
to put it into persepctive xp would be like
(xp) format. (HDD) no (xp) please? (HDD) no (xp) aww:(
weras boot and nuke
(DBAN) format (HDD) no (DBAN):mad: bitch *smack8 (HDD) ok im sorry:cry:
Peteballaghaderreen
61 (0.01/day)
Memory 8 GB
Power Supply 330W
Okay thanks for that. It now says my whole hard drive is unpartitioned space. and it's formatting the entire drive NTFS. Hopefully it will work now! If not, could it be a motherboard/bios problem?
Solaris17
27,605 (3.84/day)
Alabama
VR HMD Quest 3
no trust me youll be fine now...it was vista making life all sorts of hard.
Peteballaghaderreen
61 (0.01/day)
Memory 8 GB
Power Supply 330W
Okay format is nearly complete. just a quick lastminute double check. When it restarts,
I don't boot from disk, just let it boot from hard Drive, right?
Do I take out disk?
4,413 (0.65/day)
no, it'll need it for the next stage. Just don't touch it until it gets to the Windows load screen. (yes, boot from hdd)
