I have a Sapphire 9700 non-pro with its default BIOS. Adjusting clocks with ATITool will always cause the blank black screen of death within 10 seconds even though 'Remove Radeon 9000 .. clock lock' is checked in the Miscellaneous settings at ATITool startup by default.
I've found a reliable workaround for it though. Once each windows session before I adjust the clock for the first time I have to go into ATITool's miscellaneous settings and UNCHECK that option then RECHECK that option and overclocking with ATITool will work perfectly from then on (until a reboot of course).
This behaviour is the same with .22 and .23.
