- Mar 21, 2018
- 9 (0.00/day)
Processor | FX8320E @ 4.7GHz @ 1.5v |
Motherboard | GIGABYTE GA-970A-UD3P |
Cooling | Zalman CNPS10X Performa |
Memory | 8GB HYPERX FURY DDR3 @ 2000MHz |
Video Card(s) | R9 270X WINDFORCE 3X 1150/1550MHz |
Storage | 2X 500GB WD BLUE |
Case | CoolerMaster CM690 |
Power Supply | Corsair CX650W |
I'm trying to push my CPU to the limit. I'm currently running stable at 4.5GHz @ 1.4v with LLC on Medium in the bios.
The motherboard I have is a GA-970A-UD3P.
The problem I have is that when I try to push the multiplier higher than 22x my PC won't boot and I'll have a screen telling me that "some hardware settings are incompatible with your system" or something like that.
I'm currently running with 205MHz BCLK with a 22x multiplier to reach 4.5GHz, the problem is: I can reach higher CPU clocks by increasing the BCLK and the NB Voltage as well the CPU Vcore, but my RAM become quickly unstable when I get past 1450MHz with 9-9-9-24 or even higher timings and a higher RAM voltage.
My temps are stable, I'm using a Zalman CNPS10X Performa and getting a max of 55°C on AIDA64 running for 1 hour and a max of 60°C on the VRM.
I've already tried to update the bios, to reset the CMOS, everything I can think of I already tried and I can't raise the multiplier higher than 22x and this is driving me crazy.
Full system:
MB: GA-970A-UD3P
CPU: FX-8320E
RAM: HyperX Fury 8GB 1333MHz
PSU: Corsair TX750M
GPU: R9 270X
Full system:
MB: GA-970A-UD3P
CPU: FX-8320E
PSU: Corsair TX750M
GPU: R9 270X
