Is it possible to use 2 "unlike" processors on this board (ASUS KGPE-D16)...And if so, what do i need to do?
I recently purchased:
MOBO: ASUS KGPE-D16 server motherboard
RAID: PIKE 1078
RAM: 8 x2gb DDR3
ROM: 3 x 1TB hard drives
Optical: 2 x asus dvd/rw
PSU: Coolermaster 1000w
Case: Coolermaster HAF
CPU: AMD Opteron 6128 and AMD Opteron 6134
Awesome system with many possibilities if i can get it to run correctly.
PROBLEM: I ordered 2 AMD Opteron 6128 processors. To my benefit(or so i thought), I mistakenly received 1 AMD 6128 and 1 AMD 6134. Both processors are supported by the ASUS mobo. I called ASUS...They said "We dont recommend that you use 2 different processors" but could not tell me if it would NOT work or if it was just "not recommended".
I called AMD, they said...."It should work, but the FSB speed will only be as fast as the slowest processor.
Troubleshooting: I installed both processors. The system powered on but I did not get a video signal, and there were no POST beeps.
I removed the CPU #2 (AMD 6134) and the associated RAM...the system booted and I was able to install the OS. System works fine with one CPU. To verify that the CPU was operational, I then replaced the CPU #1 (AMD 6128) with the AMD 6134. The system worked fine. However i did have to go to the device manager and uninstall the 8 different instances of the 6128 processor, rebooted and the system updated with the correct 6134 drivers.
SO, Is it possible to use 2 "unlike" processors on this board (ASUS KGPE-D16)...And if so, what do i need to do?
Thanks for any advice or direction you can give.
RAID: PIKE 1078
RAM: 8 x2gb DDR3
