- Oct 6, 2014
- 1,424 (0.37/day)
System Name | octo1 |
Processor | dual Xeon 2687W ES |
Motherboard | Supermicro |
Cooling | dual Noctua NH-D14 |
Memory | generic ECC reg |
Video Card(s) | 2 HD7950 |
Storage | generic |
Case | Rosewill Thor |
I might not be using the right terminology so let me explain the set up.
I have a hard wired 8 port router with no wireless functionality. Why? Because at the time I couldn't find a wireless router with 8 ports. So to solve the wireless issue I got 2 access point boxes. They plug into a port on the router and then I configure them to be WPA2-PSK and create a password.
Oh and the boxs are configed to be 802.11 b/g/n so there shouldn't be any protocol issues. One is on channel 6 the other on channel 11. I have several (4) devices that currently connect to these boxes with no issues. Two android devices, a laptop and an old am/fm internet radio.
The IP camera works fine when I connect it directly to the router. I even have it port forwarded so that I can access it over the wan. But when I disconnect the cable, it goes dark. I can't even see it in the device list of the router which is odd since I can see the other wireless devices.
Now bear in mind that this is an old IP camera that I had sitting in a box for years. It's probably at least 5 years old. I just never got around to setting it up. And granted, it was probably never designed for access points although in the setup section it says it can handle both infrastructure connections and adhoc.
So I guess my question is what is the difference between a normal wireless router and an access point that could be causing this issue and what can I do to correct it?
Let me know if you need more info and thanks for any assistance.
