About one month ago, I've bought a PW6000-12 Power inverter from Amazon. Unfortunately, my brother has damaged it when he was trying to interconnect this inverter through the commercial power AC utility. It really blew up a lot of components in the circuit!
I had to change half of the power MOSFETs (IRFP260N), the driver transistors (AN1013 and SC2383), some optocouplers (PC817) and one resistor connected to MOSFET (220R). After that, it came alive again. The display was showing the correct battery voltage, the output frequency was 60Hz. But, the drawback was that the output AC power was too high, around 160V instead of 110V! Since I don't have the electrical diagram of this circuit, I have to use my knowledge and a bit of "intuition" in order to troubleshoot this issue. I could observe that the voltage in the connector CON8-1 was around 182V. Then I suspected some problem related to the Voltage gain control (feedback). I have tested some components but I couldn't find any remaining faulty component...
I would like to get some help from you in order to identify why the AC output voltage is so high now. I believe the solution is very close now. Thanks!
