Hello,
One month ago I cleaned my PC from dust using compressed air from can. The only component that I removed to clean up was the CPU fan. After this I noticed some weird lag spikes or frame drops while in a game.When I open the task bar it shows high power usage on whatever game is opened and high cpu usage. After some time passes by everything goes back to normal vallues.
I cleaned the PC again also have checked all the cables and re-seated the GPU and RAM ( cleaned with compressed air the slots). Everything seemed normal, no loose cables or anything else, but the problem persists.. Nothing helped. Went in windows 10 options and did full OS reset. Somehow the issues with the freezes,high power usage disappeared. Then the monitor lost signal and the fans started to rev up.
Yesterday I decided to move to windows 11 and clean installed it. Just started installing drivers and monitor lost signal again with fans spinning high. This happened 2-3 times in idle. I tried to run Destiny , but the game straight away crashed. I am reverting back to windows 10.
I am kinda lost what might cause those issues. There is no overheating. I stress tested the PC with temperature monitoring. Is it possible that I damaged the PSU with the compressed air or spliced the dust inside? How to troubleshoot this issue ?
The specs are:
The PC Specs are:
MB: b450 gaming
GPU:RX580
CPU: Ryzen 5 2500x
RAM: Hyper X 2666 MHZ 2x 16GB
OS now : win 11 PRO
before : win 10
The specs are:
The PC Specs are:
MB: b450 gaming
GPU:RX580
CPU: Ryzen 5 2500x
OS now : win 11 PRO
before : win 10
