Problem with raid (0) confiq
can you still boot to the raid 0 config?
i think u have to reinstal everthing but im not sure
Ahh. Try turning off AHCI in bios.
If that doesnt work. Boot into windows, run the Nvidia Storage RAID software, Find the drive that is erroring, and right click on it, and mark it as "Ok" or "Safe".
all good options, I had the same issue coming up and when I turned off the AHCI it worked fine. I also use a PCI raid card and I had to disable to onboard RAID before it would work
