problem with ram slot
4 (0.00/day)
hello guys i have problem with ram slots no working 3-4 slots when i put ram on 3 or 4 slot and start pc try to open but is off
immediately can anyone help pls i work now only with 1 2 slot
make sure the ram itself has not gone bad. take the ram from slots 1,2 that make the computer boot and put them in 3,4 leaving slots 1,2 empty.
Check the RAM socket, pins, and the RAM itself. Try to clean it up.
Also check the CPU socket and try to reseat the CPU. Sometimes if the CPU is not aligned correctly, the system won't detect RAM.
Okk thank you all guys when i check i will send message thanks again and sry for my bad english
