Problem with Samsung Un40eh5300 TV and HDMI, NO Signal.
32 (0.01/day)
Processor AMD Ryzen 5 3600
Motherboard AsRock AM4 B550 Pro4M
Cooling Stock
Memory Adata XPG Hunter 2x8GB DDR4
Video Card(s) Asus ROG Strix RTX 3070
Storage HP 1TB EX920 | WD 250GB SN550 | Seagate Barracuda 1TB | WD Blue 2x2TB
Display(s) Gigabyte G27Q
Case Cooler Master NR400
Power Supply Segotep 500W GP600G
Mouse Logitech G305
Keyboard HyperX Alloy FPS
I am having this problem for a while now. I'm trying to connect via HDMI my PC with an GTX 1050 Ti but I get "No signal" error. I tried the three different inputs with three different cables but no signal. I tried with an old GT520 and same thing, also with other CPU. I tried on a older Philips LED TV and both GPUs works. The strange part is that my netbook and notebook have no problem connecting with any cable or in any input via HDMI and works perfectly. My notebook doesn't have a battery and I can only get signal to my TV with the charger of my Netbook because the original charger doesn't give signal in this TV, works fine with any charger in the Philips TV.
A long time ago (3-4 years), I was able to connect the same PC to the same TV and worked fine, now it doesn't. I made a BIOS reset but nothing. I also tried two different PSUs and with differents power cables. I don't get signal nor BIOS and Windows.
Also tried with Win+P and nothing, also with drivers uninstalled.
Is there any way to fix this?
9,801 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Sounds like you tried anything I can think of. I gather the 1050Ti connects just fine to other monitors/TVs ?
32 (0.01/day)
Cooling Stock
Mouse Logitech G305
Yes, also does the GT520.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Samsung TV's often have one HDMI port designed for PC use, usually HDMI 1 or HDMI 2 - try all the ports
The other thing to do would be to dual monitor and see if it shows up in windows settings, and adjust things in the NVCP to lower settings - the more modern GPU may be negotiating higher settings and failing, this can also tie in with a low quality HDMI cable (older GPU's use less bandwidth so they may work better with crap cables)
32 (0.01/day)
Cooling Stock
Mouse Logitech G305
The PC doesnt detect the TV. It only shows the second monitor.
7,607 (1.44/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Groundloops?
What is going on with those?
9,801 (3.23/day)
Case Phanteks NV7
My only explanation would be that the card, for some reason, always sends an incompatible signal to the TV, i.e 3840x2160 60hz when the TV in question doesn't support that.
32 (0.01/day)
Cooling Stock
Mouse Logitech G305
But both of the GPUs? Some years ago it was working perfectly.
1,213 (0.59/day)
Canada
System Name New compy
Processor AMD Ryzen 5800x3D
Case Thermaltake Core v71
What resolution is the tv? Is tv 60hz? Try manually setting frequency, in nvidia control panel under choose resolution click customize button, then create custom resolution, set resolution and refresh to match your tv, for timing use cvt reduced blank, change scan type from interlaced to progressive or progressive to interlaced and hit test. If the test is successful you can save the custom resolution. If 60hz isn't working try 59 or 61 hz.
