Problem with Windows Movie Maker 2.6
1,027 (0.22/day)
Patna, Bihar, India, Asia, Earth, Terron System, M
System Name Oldtimer(Always Crunching)
Processor Intel P4 631 @ 3.2 GHz [Stock 3.0 GHz]
Motherboard Intel D945GCPE
Memory 512 MB x2 DDR2 (533MHZ and 366 MHZ)
Storage 160GB Sata1 7200rpm
Display(s) ViewSonic VA703m
Power Supply Normal 450W PSU
Software Windows 7 Ultimate 32bit
Well, I have recorded a Vid with Fraps and tryed to edit in MM 2.6 and the vid quality is very good in KMPlayer and the vid quality is also good in MM 2.6 without adding it to the timeline but when i add it to the timeline the vid quality gets very bad(can't read a thing) :shadedshu well i tryed to save the vid but the results are same as the timeline preview :mad:
I always edit in MM 2.6 but i never had problem like this, But when i tryed to edit it on Windows Xp on my other pc the quality was same as original. :ohwell: :eek:
Is this because of the OS?
My W7 Ultimate does not had a MM so i downloaded the MM 2.6 from Microsoft, Is this is because i use older version? :confused: I stick to Older Version because i like it's apperance.
The GPU on the problem giving PC is GMA 950, While the XP is running on GMA 3100
I also used MM 2.6 on WXP GMA 950 but it never gave me problem on XP
I think this is much info, but if you guys need more info then just post. :laugh::roll::laugh:
Just Bumping this thread:D
WOW, Looks like no one no TPU can answer this. :eek:
Common someone post here!
Or
Just tell me that you guys cannot answer it
(BUMP)
upload a screen shot of the MM settings...and and example vid if possible.
i don't do Windows Movie Maker, why don't u try Virtualdubmod?
when u got Fraps installed it gets the codec automaticly and than i would use x264 codec for the video encoding ^^
Thanks Virtualdubmod is lot better and faster then the MM
Sony Vegas Pro 10/11 would also be a good option. But it's not free. Ehm.
