- Jun 29, 2023
- 13 (0.02/day)
Processor | i7 4770 3.40 ghz |
Motherboard | Intel® Desktop Board DB85FL |
Cooling | EVGA CLC 120 Liquid / Water CPU Cooler |
Memory | 16gb ddr3 1333mhz |
Video Card(s) | MSI GeForce GTX 1650 4GT LP OC |
Storage | Toshiba DT01ACA050 500GB SATA Hard Drive, Crucial MX500 2.5 1TB SATA3 (CT1000MX500SSD1) Crucial MX50 |
Case | Cooler Master N400 ATX Mid Tower Case |
Power Supply | Seasonic FOCUS GX-550W Gold |
Hello, I've been using a TL-WN822N V5 usb wifi adapter (costs 15$ here) for a year, at first it worked well, it would drop connection at times but it was tolerable.
After booting up the pc the adapter wouldn't be recognized at all, you'd have to unplug it and plug it for the wifi networks to appear but nothing too annoying.
Yesterday, upon booting my pc, the internet connection started to drop 2-3 seconds after being connected to the wifi, even though the adapter was still blinking, so I kept trying to connect to the wifi multiple times after that without touching the adapter and after the 5th or so disconnect I got a BSOD. I waited for the BSOD to complete and after restarting the pc I got a USB device not recognized notification.
Now I'm considering buying ASUS AX1800 PCIe WiFi Adapter as I read that PCIe adapters are more stable than usb ones.
The adapter is positioned behind a column, roughly 3 meters away from the router. The wifi network band is 2.4ghz.
https://www.batna24.com/en/p/huawei-hg8245-ont-uekor - this is the router
Do you think that crappy wifi usb adapters can cause bsods or could it be something else?
PC specs:
GPU: msi gtx 1650 4GT LP OC
CPU: i7 4770 3.40 ghz
Motherboard: Intel DB85FL Desktop Motherboard
PSU: Seasonic FOCUS GX-550W Gold
RAM: 16gb ddr3 1333mhz
HDD: Toshiba DT01ACA050 500GB SATA Hard Drive
SSD: Intenso SSD SATA III 500gb
PC specs:
