Problems installing the GPU of i5-2500k
243 (0.04/day)
System Name Silverstorm
Processor Intel Core i5 2500k
Motherboard Gigabyte GA-P67A-D3-B3 (Rev. 2.0)
Memory 2x4GB Kingston HyperX PC3-12800 1600MHz CL9-9-9-27
Video Card(s) Gigabyte GeForce GTX 760 2GB
Storage 250GB Samsung 840 EVO SSD, 1TB WD Caviar Green, 2x500GB Seagate Barracuda, 2TB WD Elements (ext)
Display(s) Samsung S24B300 + HP w2207h
Case Fractal Design Define R4 Black Pearl
Audio Device(s) 7.1 CH HD Audio (Onboard)
Power Supply OCZ StealthXStream 800W
Software Microsoft Windows 10 Pro 64bit
Hey guys.
I've put together a computer today, and have succesfully installed all drivers, except the driver for the onboard GPU of the i5-2500k.
When I first installed the drivers from the dvd, everything went fine. I rebooted, and the computer got stuck with a black screen on my monitor, and it saying no-signal, after the windows logo.
So I booted into safemode, removed the GPU drivers and it booted fine again. Now I'm trying to reinstall the drivers, and all I get is "The setup failed to install one or more device drivers" when running the setup. If I try to do it manually through the device manager, it says "Windows found driver software for your device, but encountered and error while attempting to install it. Intel(R) HD Graphics Family. There is no driver selected for the device information set or element"
This occurs in safemode as well. Installing the driver through Windows Update does also not work.
Any hints to fix this?
The specs are:
Intel i5-2500k
2x4GB Kingston ValueR. DDR3 1333MHz
SUS P8H61-M PRO
Corsair CX V2 500W
Seagate Barracuda® 500GB SATA 6Gb/s
Thanks for any help.
i have had issues with my igpu as well messing up my boot. no idea how to fix it. mine kinda just fixed itself after about 100 reboots. lol also, maybe get the 2550k and send back your 2500k for a refund if its still possible. that way no igpu issues.
Problem is I cant even install the driver anymore. And I dont think I have time to return it..
I have a 2500k, but never even tried using the IGP.
I have heard that there can be motherboard options related to the default video to use. I would have thought it would default to the IGP if you have no discrete card installed.
Wish I could be more help, but I would look at the bios settings. Also try a different video output.
Of course the simplest answer is that you monitor has not selected the appropriate input. That's the kind of thing that happens to me.
Already tried fiddling with bios settings.
Fun thing... when I went out of my current safemode session, I got the black screen again. Apparantly it installed the drivers on it's own. How, I dont know.
I tried switching to a vga cable instead of hdmi, and what do you know. Got a signal. So it seems like it's just the hdmi part of the iGPU not working correctly.
Question. I seem to recall vga not being able to fully support full-hd resolution. Is that true? (Though it seems to look fine)
Not sure about resolution, but it just won't look as sharp. That I know.
Win 7 likes to go ahead and install it's own drivers for everything, which is usually fine. But if you have the driver disk for the motherboard, you could try reinstalling the video drivers. The HDMI should work.
First of all i have a Board with DVI-I, HDMI and Display Port, along with a 2500K and a GTX460, so the thing is The HDMI works perfectly it even produces sound too able to output 7.1 audio so HDMI works fine for me via 2500K The Display Port also has the ability to produce visual along with sound and up to 7.1 tried it works too, and the DVI-I i tested in both DVI-D and also used a vga adapter on it works fine, so 2500K has no problem nor the motherboard or chipset.
About VGA, vga has the ability to display a max res of 2048x1536 so i guess it does HD res with ease which are 1920x1080
Not sure I dare uninstall anything again :p
However, it is not the standard windows drivers installed. It is the actual Intel drivers, so they do work now. I'm not sure what the problem was. Gonna try to fix the hdmi if I can somehow..
I guess/highly think its an Operating System issue seen this kind of issue on a Laptop with Radeon 7670m 2GB was behaving like this after installing Windows 7 x64 ultimate then it kinda fixed it self after restarting twice but i installed the display drivers again just to confirm it has never had this problem again, so i guess it's operating system related issue
Yeah, I think I might do a full format and start over. It's giving me troubles again. Erased the actual drivers and installed the "standard vga driver" instead.
EDIT: Did that, and managed to get drivers installed and updated properly. Still no hdmi or dvi though, for whatever reason *shrugs*
