- Aug 30, 2009
- 4,012 (0.69/day)
- Sarasota, Florida, USA
System Name | Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023) |
Processor | Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz |
Motherboard | Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock |
Cooling | Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock |
Memory | G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133 |
Video Card(s) | EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530 |
Storage | Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM |
Display(s) | Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel |
Case | Fractal Design Define XL R2 | MSI |
Audio Device(s) | Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer |
Power Supply | Corsair HX850i Platinum | 19.5v 180w Delta brick |
Software | Windows 10 Pro x64 | Windows 10 Home x64 |
Hey guys,
About a week ago, my dad purchased a refurbished Netgear WNR3500 (version 1) router off of Newegg.com for $40 (retail $100) for me to use, since my last router quit working completely. It came with the latest firmware revision.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833122220
It is hooked up to the internet via the Ethernet drop that the apartment complex has installed in each bedroom. I got it all set up, including the wireless (using WPA2 Personal TKIP + AES) and I turned SSID broadcasting off to further discourage people from using my WiFi. The internet works fine, but I am having problems with Team Fortress 2 (a multi-player FPS). I can connect to servers fine, play fine, all that jazz. But, it seems that when I have played a long time and have played on multiple servers, I will search for new servers to play on, they show up, but I cannot join them. I have to unplug the power to the router, plug it back in and once it is finished booting, I can join the server. This problem doesn't happen while browsing the internet or if my desktop is plugged directly into the Ethernet drop. So, it seems that the router is becoming overloaded (maybe the NAT table is small?) and it quits serving TF2 until it is rebooted. Is there anyway I can fix this, as I am finding that I have to unplug this router every few hours. TIA.
