Processor control tool?
13,861 (1.84/day)
System Name Dark Monolith
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS Strix X570-E
Case Silverstone Kublai KL-07
I'm looking for a program that would allow me to control how CPU behaves in Windows based on different controls and factors via power plan switching.
- mouse movement
If I'm moving the mouse, this tool should keep Power plan "High performance" selected. There should be a control for mouse idle time. If I stop moving mouse for I don't know, 15 minutes, it should switch to "Balanced" or "Power Saver" automatically. As soon as I move the mouse, it should reset the timer again (and keep resetting it for as long as I'm moving the mouse).
- running applications
List of applications that I want to run with "High performance" power plan. When such app is launched, it should kick into High performance. When app is closed, it should switch back to last used state.
- manual control
Quick selection in tray icon between all 3 basic modes.
The reason I want such tool is the fact that when my CPU clocks down when not under load, it seems that clock of 1.2GHz is a bit too low, but I also don't want it to run at full speed all the time either. Giving me the mouse and app monitoring control, I could benefit from it while not wasting power, making experience in Windows smoother while still not wasteful.
Is there any such tool? If not, anyone willing to create it?
You could cheat a little by using screensaver. Create a dummy screensaver executable that is only a transparent full screen window over desktop which lowers the power state upon start and restores it upon exit.
The rest is handled by windows ... screensaver is run after some time of mouse/kb inactivity
The app closest to your requirements is process lasso, though I don't think it covers mouse movement, it does have the option to manually select high performance & then the switch to low power (or power saver) is automatic via idle saver.
