Program to Stress Test Memory
555 (0.09/day)
Indiana
System Name Evil Dragon
Processor AMD FX-8320 Vishera @4.7ghz
Motherboard Asus 970 pro gaming Aura
Cooling Corsair Hydro Series H100i V2(fully Lapped). 4 40mm NB/VRM fans. 6 Thermaltake Riing 12 Series fans
Memory 2X8gig GeIL EVO Veloce Series DDR3 1600 @9.9.9.26
Video Card(s) Powercolor Red Devil RX 480 (1400/2100)
Storage PNY XLR8 480gig SSD. Patriot Pyro SE 60gig SSD.
Display(s) ASUS VP228H LED
Case Thermaltake Core V31
Audio Device(s) Onboard Realtek ALC1150 W/Creative Sound Blaster Cinema 2
Power Supply EVGA 850 BQ 110
Keyboard Roccat Isku FX
Looking for a good program to really stress test memory. I know of Memtest86 and Windows Mem test, but I am not sure which to use. I want something that will throw alot of data at it very fast.
Basicly, if there is a fault or an stability issue of any kind I want the test to find it. ;)
The new Memtest86+ should find pretty much any memory instabilty/errors if any. Just let it run overnight and if there's no errors, it's pretty safe to say the memory is good/stable.
A very good program to stress test memory is SuperPi Mod1.5 - IMO if it passes 8M the memory will be stable.
rightmark do some good stuff..
http://www.rightmark.org/
if u want a quick and dirty stability test run super pi to 16m and 3dmark 2006 at the same time..
otherwise running the rightmark memory stabilty test in the background while u browse or do your other day to day stuff will soon find problems if there are any..
running orthos for x number of hours is a waste of space.. its a "pretend" stability test..
trog
I agree that rightmark has some good stuff, I disagree with orthos aside from testing memory. It's a good dual core CPU stress imo, but for memory, it's a waste of time. But small fft's on Priority 9 does a good job of heating the cpu, to me it's just a cobbled Prime95 for dual cores...which it pretty much is.
I still use Memtest for Windows Free initially...but the best route is to create a boot disc so less memory is taken up by an OS and thus more memory can be tested and verified. I usually start with all sticks installed, if there are errors, I'll remove a stick (I am running a 2x1gb kit)...and even if I found only one has errors, I'll test the other to ensure it's integrity.
There are a few different methods to do this, some are more popular than others, but most will get to the same conclusion if performed correctly.
:toast:
Prime95 is my favorite for RAM and CPU testing
