- Dec 22, 2007
- 184 (0.03/day)
- Central Nebraska
System Name | CORSAIR |
Processor | AMD Phenom 1090T x6 @3.2 |
Motherboard | Gigabyte Ga-78LMT-S2P |
Cooling | High efficiency dust cooling |
Memory | 8GB GSkill DDR3 1333 |
Video Card(s) | Sapphire Radeon HD3870 512MB GDDR4 PCI-e toxic |
Storage | Seagate SV35.3 ST3250310SV 250GB SATAII(Windows 7 Pro x64), 320GB Samsung SATAII(Storage and SuSE) |
Display(s) | Dell 20" LCD, Dell 17" LCD |
Power Supply | Antec Cool Blue 650W Modular |
Software | Windows 7 Professional SP1, Visual Studio 2010 Ultimate |
I'm posting this code because I looked EVERYWHERE and no one had any samples to start out with. I needed a simple way to protect a program I intend to sell from being distributed for free, without "punishing the honest user."
You are free to use the code, just please make some not of thanks in your program. Also: if you are not a TPU forum member and use the code, I ask that you please sign up on the Tech Power Up forums and give something back (knowledge, help, etc.) to someone else in need.
This is probably by FAR NOT the best way to this, but it's all I could come up with that didn't involve hardware on the machine. I do not have a key generator to go along with it... but the following key will validate with the included project file if run:
"0C660-A0006-0C660-G0088".
I have implemented a different final version into my own program, but here is the basic code in a nutshell. I tried to include comments to explain as I went. If you feel you would like to contribute and make this code better, please feel free to do so and re upload the project file for others to continue to build on.
Kreij and Ford: Personal challenge! How would you improve this?
I have a key generator that is about half done. If anyone knows how to add items to a listbox on a thread other than the main thread, let me know, and I'll finish that up and post it here as well.
Code:
'Original Code by Sean Huggans (shuggans)
'Provided for use by Tech Power Up forum members (If you grab this code, please sign up for TPU!)
'9/13/2011
Public Class Form1
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
TextBox_GroupA.MaxLength = 5
TextBox_GroupB.MaxLength = 5
TextBox_GroupC.MaxLength = 5
TextBox_GroupD.MaxLength = 5
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
'grab all textbox strings....
Dim GroupA As String = TextBox_GroupA.Text.ToUpper
Dim GroupB As String = TextBox_GroupB.Text.ToUpper
Dim GroupC As String = TextBox_GroupC.Text.ToUpper
Dim GroupD As String = TextBox_GroupD.Text.ToUpper
'------ check to make sure there are 5 characters in each text box... these numbers could be changed to add security or mix it up a bit.... you'd need to set the textbox maxlength above to match, and delete the corresponding strings below.
If GroupA.Length = 5 And GroupB.Length = 5 And GroupC.Length = 5 And GroupD.Length = 5 Then
'----- break our textbox strings into individual character strings
Dim char1 As String = GroupA.Chars(0)
Dim char2 As String = GroupA.Chars(1)
Dim char3 As String = GroupA.Chars(2)
Dim char4 As String = GroupA.Chars(3)
Dim char5 As String = GroupA.Chars(4)
Dim char6 As String = GroupB.Chars(0)
Dim char7 As String = GroupB.Chars(1)
Dim char8 As String = GroupB.Chars(2)
Dim char9 As String = GroupB.Chars(3)
Dim char10 As String = GroupB.Chars(4)
Dim char11 As String = GroupC.Chars(0)
Dim char12 As String = GroupC.Chars(1)
Dim char13 As String = GroupC.Chars(2)
Dim char14 As String = GroupC.Chars(3)
Dim char15 As String = GroupC.Chars(4)
Dim char16 As String = GroupD.Chars(0)
Dim char17 As String = GroupD.Chars(1)
Dim char18 As String = GroupD.Chars(2)
Dim char19 As String = GroupD.Chars(3)
Dim char20 As String = GroupD.Chars(4)
'---- give all our characters a numeric value if they are letters. I would change this up as well if you are actually going to implement this code.
If char1 = "A" Then
char1 = "10"
ElseIf char1 = "B" Then
char1 = "11"
ElseIf char1 = "C" Then
char1 = "12"
ElseIf char1 = "D" Then
char1 = "13"
ElseIf char1 = "E" Then
char1 = "14"
ElseIf char1 = "F" Then
char1 = "15"
ElseIf char1 = "G" Then
char1 = "16"
ElseIf char1 = "H" Then
char1 = "17"
ElseIf char1 = "I" Then
char1 = "18"
ElseIf char1 = "J" Then
char1 = "19"
ElseIf char1 = "K" Then
char1 = "20"
ElseIf char1 = "L" Then
char1 = "21"
ElseIf char1 = "M" Then
char1 = "22"
ElseIf char1 = "N" Then
char1 = "23"
ElseIf char1 = "O" Then
char1 = "24"
ElseIf char1 = "P" Then
char1 = "25"
ElseIf char1 = "Q" Then
char1 = "26"
ElseIf char1 = "R" Then
char1 = "27"
ElseIf char1 = "S" Then
char1 = "28"
ElseIf char1 = "T" Then
char1 = "29"
ElseIf char1 = "U" Then
char1 = "30"
ElseIf char1 = "V" Then
char1 = "31"
ElseIf char1 = "W" Then
char1 = "32"
ElseIf char1 = "X" Then
char1 = "33"
ElseIf char1 = "Y" Then
char1 = "34"
ElseIf char1 = "Z" Then
char1 = "35"
End If
If char2 = "A" Then
char2 = "10"
ElseIf char2 = "B" Then
char2 = "11"
ElseIf char2 = "C" Then
char2 = "12"
ElseIf char2 = "D" Then
char2 = "13"
ElseIf char2 = "E" Then
char2 = "14"
ElseIf char2 = "F" Then
char2 = "15"
ElseIf char2 = "G" Then
char2 = "16"
ElseIf char2 = "H" Then
char2 = "17"
ElseIf char2 = "I" Then
char2 = "18"
ElseIf char2 = "J" Then
char2 = "19"
ElseIf char2 = "K" Then
char2 = "20"
ElseIf char2 = "L" Then
char2 = "21"
ElseIf char2 = "M" Then
char2 = "22"
ElseIf char2 = "N" Then
char2 = "23"
ElseIf char2 = "O" Then
char2 = "24"
ElseIf char2 = "P" Then
char2 = "25"
ElseIf char2 = "Q" Then
char2 = "26"
ElseIf char2 = "R" Then
char2 = "27"
ElseIf char2 = "S" Then
char2 = "28"
ElseIf char2 = "T" Then
char2 = "29"
ElseIf char2 = "U" Then
char2 = "30"
ElseIf char2 = "V" Then
char2 = "31"
ElseIf char2 = "W" Then
char2 = "32"
ElseIf char2 = "X" Then
char2 = "33"
ElseIf char2 = "Y" Then
char2 = "34"
ElseIf char2 = "Z" Then
char2 = "35"
End If
If char3 = "A" Then
char3 = "10"
ElseIf char3 = "B" Then
char3 = "11"
ElseIf char3 = "C" Then
char3 = "12"
ElseIf char3 = "D" Then
char3 = "13"
ElseIf char3 = "E" Then
char3 = "14"
ElseIf char3 = "F" Then
char3 = "15"
ElseIf char3 = "G" Then
char3 = "16"
ElseIf char3 = "H" Then
char3 = "17"
ElseIf char3 = "I" Then
char3 = "18"
ElseIf char3 = "J" Then
char3 = "19"
ElseIf char3 = "K" Then
char3 = "20"
ElseIf char3 = "L" Then
char3 = "21"
ElseIf char3 = "M" Then
char3 = "22"
ElseIf char3 = "N" Then
char3 = "23"
ElseIf char3 = "O" Then
char3 = "24"
ElseIf char3 = "P" Then
char3 = "25"
ElseIf char3 = "Q" Then
char3 = "26"
ElseIf char3 = "R" Then
char3 = "27"
ElseIf char3 = "S" Then
char3 = "28"
ElseIf char3 = "T" Then
char3 = "29"
ElseIf char3 = "U" Then
char3 = "30"
ElseIf char3 = "V" Then
char3 = "31"
ElseIf char3 = "W" Then
char3 = "32"
ElseIf char3 = "X" Then
char3 = "33"
ElseIf char3 = "Y" Then
char3 = "34"
ElseIf char3 = "Z" Then
char3 = "35"
End If
If char4 = "A" Then
char4 = "10"
ElseIf char4 = "B" Then
char4 = "11"
ElseIf char4 = "C" Then
char4 = "12"
ElseIf char4 = "D" Then
char4 = "13"
ElseIf char4 = "E" Then
char4 = "14"
ElseIf char4 = "F" Then
char4 = "15"
ElseIf char4 = "G" Then
char4 = "16"
ElseIf char4 = "H" Then
char4 = "17"
ElseIf char4 = "I" Then
char4 = "18"
ElseIf char4 = "J" Then
char4 = "19"
ElseIf char4 = "K" Then
char4 = "20"
ElseIf char4 = "L" Then
char4 = "21"
ElseIf char4 = "M" Then
char4 = "22"
ElseIf char4 = "N" Then
char4 = "23"
ElseIf char4 = "O" Then
char4 = "24"
ElseIf char4 = "P" Then
char4 = "25"
ElseIf char4 = "Q" Then
char4 = "26"
ElseIf char4 = "R" Then
char4 = "27"
ElseIf char4 = "S" Then
char4 = "28"
ElseIf char4 = "T" Then
char4 = "29"
ElseIf char4 = "U" Then
char4 = "30"
ElseIf char4 = "V" Then
char4 = "31"
ElseIf char4 = "W" Then
char4 = "32"
ElseIf char4 = "X" Then
char4 = "33"
ElseIf char4 = "Y" Then
char4 = "34"
ElseIf char4 = "Z" Then
char4 = "35"
End If
If char5 = "A" Then
char5 = "10"
ElseIf char5 = "B" Then
char5 = "11"
ElseIf char5 = "C" Then
char5 = "12"
ElseIf char5 = "D" Then
char5 = "13"
ElseIf char5 = "E" Then
char5 = "14"
ElseIf char5 = "F" Then
char5 = "15"
ElseIf char5 = "G" Then
char5 = "16"
ElseIf char5 = "H" Then
char5 = "17"
ElseIf char5 = "I" Then
char5 = "18"
ElseIf char5 = "J" Then
char5 = "19"
ElseIf char5 = "K" Then
char5 = "20"
ElseIf char5 = "L" Then
char5 = "21"
ElseIf char5 = "M" Then
char5 = "22"
ElseIf char5 = "N" Then
char5 = "23"
ElseIf char5 = "O" Then
char5 = "24"
ElseIf char5 = "P" Then
char5 = "25"
ElseIf char5 = "Q" Then
char5 = "26"
ElseIf char5 = "R" Then
char5 = "27"
ElseIf char5 = "S" Then
char5 = "28"
ElseIf char5 = "T" Then
char5 = "29"
ElseIf char5 = "U" Then
char5 = "30"
ElseIf char5 = "V" Then
char5 = "31"
ElseIf char5 = "W" Then
char5 = "32"
ElseIf char5 = "X" Then
char5 = "33"
ElseIf char5 = "Y" Then
char5 = "34"
ElseIf char5 = "Z" Then
char5 = "35"
End If
If char6 = "A" Then
char6 = "10"
ElseIf char6 = "B" Then
char6 = "11"
ElseIf char6 = "C" Then
char6 = "12"
ElseIf char6 = "D" Then
char6 = "13"
ElseIf char6 = "E" Then
char6 = "14"
ElseIf char6 = "F" Then
char6 = "15"
ElseIf char6 = "G" Then
char6 = "16"
ElseIf char6 = "H" Then
char6 = "17"
ElseIf char6 = "I" Then
char6 = "18"
ElseIf char6 = "J" Then
char6 = "19"
ElseIf char6 = "K" Then
char6 = "20"
ElseIf char6 = "L" Then
char6 = "21"
ElseIf char6 = "M" Then
char6 = "22"
ElseIf char6 = "N" Then
char6 = "23"
ElseIf char6 = "O" Then
char6 = "24"
ElseIf char6 = "P" Then
char6 = "25"
ElseIf char6 = "Q" Then
char6 = "26"
ElseIf char6 = "R" Then
char6 = "27"
ElseIf char6 = "S" Then
char6 = "28"
ElseIf char6 = "T" Then
char6 = "29"
ElseIf char6 = "U" Then
char6 = "30"
ElseIf char6 = "V" Then
char6 = "31"
ElseIf char6 = "W" Then
char6 = "32"
ElseIf char6 = "X" Then
char6 = "33"
ElseIf char6 = "Y" Then
char6 = "34"
ElseIf char6 = "Z" Then
char6 = "35"
End If
If char7 = "A" Then
char7 = "10"
ElseIf char7 = "B" Then
char7 = "11"
ElseIf char7 = "C" Then
char7 = "12"
ElseIf char7 = "D" Then
char7 = "13"
ElseIf char7 = "E" Then
char7 = "14"
ElseIf char7 = "F" Then
char7 = "15"
ElseIf char7 = "G" Then
char7 = "16"
ElseIf char7 = "H" Then
char7 = "17"
ElseIf char7 = "I" Then
char7 = "18"
ElseIf char7 = "J" Then
char7 = "19"
ElseIf char7 = "K" Then
char7 = "20"
ElseIf char7 = "L" Then
char7 = "21"
ElseIf char7 = "M" Then
char7 = "22"
ElseIf char7 = "N" Then
char7 = "23"
ElseIf char7 = "O" Then
char7 = "24"
ElseIf char7 = "P" Then
char7 = "25"
ElseIf char7 = "Q" Then
char7 = "26"
ElseIf char7 = "R" Then
char7 = "27"
ElseIf char7 = "S" Then
char7 = "28"
ElseIf char7 = "T" Then
char7 = "29"
ElseIf char7 = "U" Then
char7 = "30"
ElseIf char7 = "V" Then
char7 = "31"
ElseIf char7 = "W" Then
char7 = "32"
ElseIf char7 = "X" Then
char7 = "33"
ElseIf char7 = "Y" Then
char7 = "34"
ElseIf char7 = "Z" Then
char7 = "35"
End If
If char8 = "A" Then
char8 = "10"
ElseIf char8 = "B" Then
char8 = "11"
ElseIf char8 = "C" Then
char8 = "12"
ElseIf char8 = "D" Then
char8 = "13"
ElseIf char8 = "E" Then
char8 = "14"
ElseIf char8 = "F" Then
char8 = "15"
ElseIf char8 = "G" Then
char8 = "16"
ElseIf char8 = "H" Then
char8 = "17"
ElseIf char8 = "I" Then
char8 = "18"
ElseIf char8 = "J" Then
char8 = "19"
ElseIf char8 = "K" Then
char8 = "20"
ElseIf char8 = "L" Then
char8 = "21"
ElseIf char8 = "M" Then
char8 = "22"
ElseIf char8 = "N" Then
char8 = "23"
ElseIf char8 = "O" Then
char8 = "24"
ElseIf char8 = "P" Then
char8 = "25"
ElseIf char8 = "Q" Then
char8 = "26"
ElseIf char8 = "R" Then
char8 = "27"
ElseIf char8 = "S" Then
char8 = "28"
ElseIf char8 = "T" Then
char8 = "29"
ElseIf char8 = "U" Then
char8 = "30"
ElseIf char8 = "V" Then
char8 = "31"
ElseIf char8 = "W" Then
char8 = "32"
ElseIf char8 = "X" Then
char8 = "33"
ElseIf char8 = "Y" Then
char8 = "34"
ElseIf char8 = "Z" Then
char8 = "35"
End If
If char9 = "A" Then
char9 = "10"
ElseIf char9 = "B" Then
char9 = "11"
ElseIf char9 = "C" Then
char9 = "12"
ElseIf char9 = "D" Then
char9 = "13"
ElseIf char9 = "E" Then
char9 = "14"
ElseIf char9 = "F" Then
char9 = "15"
ElseIf char9 = "G" Then
char9 = "16"
ElseIf char9 = "H" Then
char9 = "17"
ElseIf char9 = "I" Then
char9 = "18"
ElseIf char9 = "J" Then
char9 = "19"
ElseIf char9 = "K" Then
char9 = "20"
ElseIf char9 = "L" Then
char9 = "21"
ElseIf char9 = "M" Then
char9 = "22"
ElseIf char9 = "N" Then
char9 = "23"
ElseIf char9 = "O" Then
char9 = "24"
ElseIf char9 = "P" Then
char9 = "25"
ElseIf char9 = "Q" Then
char9 = "26"
ElseIf char9 = "R" Then
char9 = "27"
ElseIf char9 = "S" Then
char9 = "28"
ElseIf char9 = "T" Then
char9 = "29"
ElseIf char9 = "U" Then
char9 = "30"
ElseIf char9 = "V" Then
char9 = "31"
ElseIf char9 = "W" Then
char9 = "32"
ElseIf char9 = "X" Then
char9 = "33"
ElseIf char9 = "Y" Then
char9 = "34"
ElseIf char9 = "Z" Then
char9 = "35"
End If
If char10 = "A" Then
char10 = "10"
ElseIf char10 = "B" Then
char10 = "11"
ElseIf char10 = "C" Then
char10 = "12"
ElseIf char10 = "D" Then
char10 = "13"
ElseIf char10 = "E" Then
char10 = "14"
ElseIf char10 = "F" Then
char10 = "15"
ElseIf char10 = "G" Then
char10 = "16"
ElseIf char10 = "H" Then
char10 = "17"
ElseIf char10 = "I" Then
char10 = "18"
ElseIf char10 = "J" Then
char10 = "19"
ElseIf char10 = "K" Then
char10 = "20"
ElseIf char10 = "L" Then
char10 = "21"
ElseIf char10 = "M" Then
char10 = "22"
ElseIf char10 = "N" Then
char10 = "23"
ElseIf char10 = "O" Then
char10 = "24"
ElseIf char10 = "P" Then
char10 = "25"
ElseIf char10 = "Q" Then
char10 = "26"
ElseIf char10 = "R" Then
char10 = "27"
ElseIf char10 = "S" Then
char10 = "28"
ElseIf char10 = "T" Then
char10 = "29"
ElseIf char10 = "U" Then
char10 = "30"
ElseIf char10 = "V" Then
char10 = "31"
ElseIf char10 = "W" Then
char10 = "32"
ElseIf char10 = "X" Then
char10 = "33"
ElseIf char10 = "Y" Then
char10 = "34"
ElseIf char10 = "Z" Then
char10 = "35"
End If
If char11 = "A" Then
char11 = "10"
ElseIf char11 = "B" Then
char11 = "11"
ElseIf char11 = "C" Then
char11 = "12"
ElseIf char11 = "D" Then
char11 = "13"
ElseIf char11 = "E" Then
char11 = "14"
ElseIf char11 = "F" Then
char11 = "15"
ElseIf char11 = "G" Then
char11 = "16"
ElseIf char11 = "H" Then
char11 = "17"
ElseIf char11 = "I" Then
char11 = "18"
ElseIf char11 = "J" Then
char11 = "19"
ElseIf char11 = "K" Then
char11 = "20"
ElseIf char11 = "L" Then
char11 = "21"
ElseIf char11 = "M" Then
char11 = "22"
ElseIf char11 = "N" Then
char11 = "23"
ElseIf char11 = "O" Then
char11 = "24"
ElseIf char11 = "P" Then
char11 = "25"
ElseIf char11 = "Q" Then
char11 = "26"
ElseIf char11 = "R" Then
char11 = "27"
ElseIf char11 = "S" Then
char11 = "28"
ElseIf char11 = "T" Then
char11 = "29"
ElseIf char11 = "U" Then
char11 = "30"
ElseIf char11 = "V" Then
char11 = "31"
ElseIf char11 = "W" Then
char11 = "32"
ElseIf char11 = "X" Then
char11 = "33"
ElseIf char11 = "Y" Then
char11 = "34"
ElseIf char11 = "Z" Then
char11 = "35"
End If
If char12 = "A" Then
char12 = "10"
ElseIf char12 = "B" Then
char12 = "11"
ElseIf char12 = "C" Then
char12 = "12"
ElseIf char12 = "D" Then
char12 = "13"
ElseIf char12 = "E" Then
char12 = "14"
ElseIf char12 = "F" Then
char12 = "15"
ElseIf char12 = "G" Then
char12 = "16"
ElseIf char12 = "H" Then
char12 = "17"
ElseIf char12 = "I" Then
char12 = "18"
ElseIf char12 = "J" Then
char12 = "19"
ElseIf char12 = "K" Then
char12 = "20"
ElseIf char12 = "L" Then
char12 = "21"
ElseIf char12 = "M" Then
char12 = "22"
ElseIf char12 = "N" Then
char12 = "23"
ElseIf char12 = "O" Then
char12 = "24"
ElseIf char12 = "P" Then
char12 = "25"
ElseIf char12 = "Q" Then
char12 = "26"
ElseIf char12 = "R" Then
char12 = "27"
ElseIf char12 = "S" Then
char12 = "28"
ElseIf char12 = "T" Then
char12 = "29"
ElseIf char12 = "U" Then
char12 = "30"
ElseIf char12 = "V" Then
char12 = "31"
ElseIf char12 = "W" Then
char12 = "32"
ElseIf char12 = "X" Then
char12 = "33"
ElseIf char12 = "Y" Then
char12 = "34"
ElseIf char12 = "Z" Then
char12 = "35"
End If
If char13 = "A" Then
char13 = "10"
ElseIf char13 = "B" Then
char13 = "11"
ElseIf char13 = "C" Then
char13 = "12"
ElseIf char13 = "D" Then
char13 = "13"
ElseIf char13 = "E" Then
char13 = "14"
ElseIf char13 = "F" Then
char13 = "15"
ElseIf char13 = "G" Then
char13 = "16"
ElseIf char13 = "H" Then
char13 = "17"
ElseIf char13 = "I" Then
char13 = "18"
ElseIf char13 = "J" Then
char13 = "19"
ElseIf char13 = "K" Then
char13 = "20"
ElseIf char13 = "L" Then
char13 = "21"
ElseIf char13 = "M" Then
char13 = "22"
ElseIf char13 = "N" Then
char13 = "23"
ElseIf char13 = "O" Then
char13 = "24"
ElseIf char13 = "P" Then
char13 = "25"
ElseIf char13 = "Q" Then
char13 = "26"
ElseIf char13 = "R" Then
char13 = "27"
ElseIf char13 = "S" Then
char13 = "28"
ElseIf char13 = "T" Then
char13 = "29"
ElseIf char13 = "U" Then
char13 = "30"
ElseIf char13 = "V" Then
char13 = "31"
ElseIf char13 = "W" Then
char13 = "32"
ElseIf char13 = "X" Then
char13 = "33"
ElseIf char13 = "Y" Then
char13 = "34"
ElseIf char13 = "Z" Then
char13 = "35"
End If
If char14 = "A" Then
char14 = "10"
ElseIf char14 = "B" Then
char14 = "11"
ElseIf char14 = "C" Then
char14 = "12"
ElseIf char14 = "D" Then
char14 = "13"
ElseIf char14 = "E" Then
char14 = "14"
ElseIf char14 = "F" Then
char14 = "15"
ElseIf char14 = "G" Then
char14 = "16"
ElseIf char14 = "H" Then
char14 = "17"
ElseIf char14 = "I" Then
char14 = "18"
ElseIf char14 = "J" Then
char14 = "19"
ElseIf char14 = "K" Then
char14 = "20"
ElseIf char14 = "L" Then
char14 = "21"
ElseIf char14 = "M" Then
char14 = "22"
ElseIf char14 = "N" Then
char14 = "23"
ElseIf char14 = "O" Then
char14 = "24"
ElseIf char14 = "P" Then
char14 = "25"
ElseIf char14 = "Q" Then
char14 = "26"
ElseIf char14 = "R" Then
char14 = "27"
ElseIf char14 = "S" Then
char14 = "28"
ElseIf char14 = "T" Then
char14 = "29"
ElseIf char14 = "U" Then
char14 = "30"
ElseIf char14 = "V" Then
char14 = "31"
ElseIf char14 = "W" Then
char14 = "32"
ElseIf char14 = "X" Then
char14 = "33"
ElseIf char14 = "Y" Then
char14 = "34"
ElseIf char14 = "Z" Then
char14 = "35"
End If
If char15 = "A" Then
char15 = "10"
ElseIf char15 = "B" Then
char15 = "11"
ElseIf char15 = "C" Then
char15 = "12"
ElseIf char15 = "D" Then
char15 = "13"
ElseIf char15 = "E" Then
char15 = "14"
ElseIf char15 = "F" Then
char15 = "15"
ElseIf char15 = "G" Then
char15 = "16"
ElseIf char15 = "H" Then
char15 = "17"
ElseIf char15 = "I" Then
char15 = "18"
ElseIf char15 = "J" Then
char15 = "19"
ElseIf char15 = "K" Then
char15 = "20"
ElseIf char15 = "L" Then
char15 = "21"
ElseIf char15 = "M" Then
char15 = "22"
ElseIf char15 = "N" Then
char15 = "23"
ElseIf char15 = "O" Then
char15 = "24"
ElseIf char15 = "P" Then
char15 = "25"
ElseIf char15 = "Q" Then
char15 = "26"
ElseIf char15 = "R" Then
char15 = "27"
ElseIf char15 = "S" Then
char15 = "28"
ElseIf char15 = "T" Then
char15 = "29"
ElseIf char15 = "U" Then
char15 = "30"
ElseIf char15 = "V" Then
char15 = "31"
ElseIf char15 = "W" Then
char15 = "32"
ElseIf char15 = "X" Then
char15 = "33"
ElseIf char15 = "Y" Then
char15 = "34"
ElseIf char15 = "Z" Then
char15 = "35"
End If
If char16 = "A" Then
char16 = "10"
ElseIf char16 = "B" Then
char16 = "11"
ElseIf char16 = "C" Then
char16 = "12"
ElseIf char16 = "D" Then
char16 = "13"
ElseIf char16 = "E" Then
char16 = "14"
ElseIf char16 = "F" Then
char16 = "15"
ElseIf char16 = "G" Then
char16 = "16"
ElseIf char16 = "H" Then
char16 = "17"
ElseIf char16 = "I" Then
char16 = "18"
ElseIf char16 = "J" Then
char16 = "19"
ElseIf char16 = "K" Then
char16 = "20"
ElseIf char16 = "L" Then
char16 = "21"
ElseIf char16 = "M" Then
char16 = "22"
ElseIf char16 = "N" Then
char16 = "23"
ElseIf char16 = "O" Then
char16 = "24"
ElseIf char16 = "P" Then
char16 = "25"
ElseIf char16 = "Q" Then
char16 = "26"
ElseIf char16 = "R" Then
char16 = "27"
ElseIf char16 = "S" Then
char16 = "28"
ElseIf char16 = "T" Then
char16 = "29"
ElseIf char16 = "U" Then
char16 = "30"
ElseIf char16 = "V" Then
char16 = "31"
ElseIf char16 = "W" Then
char16 = "32"
ElseIf char16 = "X" Then
char16 = "33"
ElseIf char16 = "Y" Then
char16 = "34"
ElseIf char16 = "Z" Then
char16 = "35"
End If
If char17 = "A" Then
char17 = "10"
ElseIf char17 = "B" Then
char17 = "11"
ElseIf char17 = "C" Then
char17 = "12"
ElseIf char17 = "D" Then
char17 = "13"
ElseIf char17 = "E" Then
char17 = "14"
ElseIf char17 = "F" Then
char17 = "15"
ElseIf char17 = "G" Then
char17 = "16"
ElseIf char17 = "H" Then
char17 = "17"
ElseIf char17 = "I" Then
char17 = "18"
ElseIf char17 = "J" Then
char17 = "19"
ElseIf char17 = "K" Then
char17 = "20"
ElseIf char17 = "L" Then
char17 = "21"
ElseIf char17 = "M" Then
char17 = "22"
ElseIf char17 = "N" Then
char17 = "23"
ElseIf char17 = "O" Then
char17 = "24"
ElseIf char17 = "P" Then
char17 = "25"
ElseIf char17 = "Q" Then
char17 = "26"
ElseIf char17 = "R" Then
char17 = "27"
ElseIf char17 = "S" Then
char17 = "28"
ElseIf char17 = "T" Then
char17 = "29"
ElseIf char17 = "U" Then
char17 = "30"
ElseIf char17 = "V" Then
char17 = "31"
ElseIf char17 = "W" Then
char17 = "32"
ElseIf char17 = "X" Then
char17 = "33"
ElseIf char17 = "Y" Then
char17 = "34"
ElseIf char17 = "Z" Then
char17 = "35"
End If
If char18 = "A" Then
char18 = "10"
ElseIf char18 = "B" Then
char18 = "11"
ElseIf char18 = "C" Then
char18 = "12"
ElseIf char18 = "D" Then
char18 = "13"
ElseIf char18 = "E" Then
char18 = "14"
ElseIf char18 = "F" Then
char18 = "15"
ElseIf char18 = "G" Then
char18 = "16"
ElseIf char18 = "H" Then
char18 = "17"
ElseIf char18 = "I" Then
char18 = "18"
ElseIf char18 = "J" Then
char18 = "19"
ElseIf char18 = "K" Then
char18 = "20"
ElseIf char18 = "L" Then
char18 = "21"
ElseIf char18 = "M" Then
char18 = "22"
ElseIf char18 = "N" Then
char18 = "23"
ElseIf char18 = "O" Then
char18 = "24"
ElseIf char18 = "P" Then
char18 = "25"
ElseIf char18 = "Q" Then
char18 = "26"
ElseIf char18 = "R" Then
char18 = "27"
ElseIf char18 = "S" Then
char18 = "28"
ElseIf char18 = "T" Then
char18 = "29"
ElseIf char18 = "U" Then
char18 = "30"
ElseIf char18 = "V" Then
char18 = "31"
ElseIf char18 = "W" Then
char18 = "32"
ElseIf char18 = "X" Then
char18 = "33"
ElseIf char18 = "Y" Then
char18 = "34"
ElseIf char18 = "Z" Then
char18 = "35"
End If
If char19 = "A" Then
char19 = "10"
ElseIf char19 = "B" Then
char19 = "11"
ElseIf char19 = "C" Then
char19 = "12"
ElseIf char19 = "D" Then
char19 = "13"
ElseIf char19 = "E" Then
char19 = "14"
ElseIf char19 = "F" Then
char19 = "15"
ElseIf char19 = "G" Then
char19 = "16"
ElseIf char19 = "H" Then
char19 = "17"
ElseIf char19 = "I" Then
char19 = "18"
ElseIf char19 = "J" Then
char19 = "19"
ElseIf char19 = "K" Then
char19 = "20"
ElseIf char19 = "L" Then
char19 = "21"
ElseIf char19 = "M" Then
char19 = "22"
ElseIf char19 = "N" Then
char19 = "23"
ElseIf char19 = "O" Then
char19 = "24"
ElseIf char19 = "P" Then
char19 = "25"
ElseIf char19 = "Q" Then
char19 = "26"
ElseIf char19 = "R" Then
char19 = "27"
ElseIf char19 = "S" Then
char19 = "28"
ElseIf char19 = "T" Then
char19 = "29"
ElseIf char19 = "U" Then
char19 = "30"
ElseIf char19 = "V" Then
char19 = "31"
ElseIf char19 = "W" Then
char19 = "32"
ElseIf char19 = "X" Then
char19 = "33"
ElseIf char19 = "Y" Then
char19 = "34"
ElseIf char19 = "Z" Then
char19 = "35"
End If
If char20 = "A" Then
char20 = "10"
ElseIf char20 = "B" Then
char20 = "11"
ElseIf char20 = "C" Then
char20 = "12"
ElseIf char20 = "D" Then
char20 = "13"
ElseIf char20 = "E" Then
char20 = "14"
ElseIf char20 = "F" Then
char20 = "15"
ElseIf char20 = "G" Then
char20 = "16"
ElseIf char20 = "H" Then
char20 = "17"
ElseIf char20 = "I" Then
char20 = "18"
ElseIf char20 = "J" Then
char20 = "19"
ElseIf char20 = "K" Then
char20 = "20"
ElseIf char20 = "L" Then
char20 = "21"
ElseIf char20 = "M" Then
char20 = "22"
ElseIf char20 = "N" Then
char20 = "23"
ElseIf char20 = "O" Then
char20 = "24"
ElseIf char20 = "P" Then
char20 = "25"
ElseIf char20 = "Q" Then
char20 = "26"
ElseIf char20 = "R" Then
char20 = "27"
ElseIf char20 = "S" Then
char20 = "28"
ElseIf char20 = "T" Then
char20 = "29"
ElseIf char20 = "U" Then
char20 = "30"
ElseIf char20 = "V" Then
char20 = "31"
ElseIf char20 = "W" Then
char20 = "32"
ElseIf char20 = "X" Then
char20 = "33"
ElseIf char20 = "Y" Then
char20 = "34"
ElseIf char20 = "Z" Then
char20 = "35"
End If
'----- if none of the characters are spaces:
If char1 <> " " And char2 <> " " And char3 <> " " And char4 <> " " And char5 <> " " And char6 <> " " And char7 <> " " And char8 <> " " And char9 <> " " And char10 <> " " And char11 <> " " And char12 <> " " And char13 <> " " And char14 <> " " And char15 <> " " And char16 <> " " And char17 <> " " And char18 <> " " And char19 <> " " And char20 <> " " Then
'------- Now that all our values are numeric, we can add them as integers within the same group they where entered in....(you could change this up too... it'd get complex quick though)
Dim Group1 As Integer = Int(char5) + Int(char4) + Int(char3) + Int(char2) + Int(char1)
Dim Group2 As Integer = Int(char10) + Int(char9) + Int(char8) + Int(char7) + Int(char6)
Dim Group3 As Integer = Int(char15) + Int(char14) + Int(char13) + Int(char12) + Int(char11)
Dim Group4 As Integer = Int(char20) + Int(char19) + Int(char18) + Int(char17) + Int(char16)
'--------- I would take everything other than the nested if on this part out if you actually use the code in your program. The good\bad labels and text boxes are just for your own testing. -----------
TextBox_Result.Text = Group1
TextBox_Result2.Text = Group2
TextBox_Result3.Text = Group3
TextBox_Result4.Text = Group4
'-----All fields in the end will equal 96 for this sample. All groups could equal 24 if you like. BUT we'll mix it up to avoid using the same set accross all fields. we -8 from one field, and must add it to another.
'group a must = 24
If Group1 = 24 Then
Label_GroupA_Val.Text = "Good"
'group b must = 16
If Group2 = 16 Then
Label_GroupB_Val.Text = "Good"
'group c must = 24
If Group3 = 24 Then
Label_GroupC_Val.Text = "Good"
'group d must = 32
If Group4 = 32 Then
Label_GroupD_Val.Text = "Good"
'------------------- If all four of our seperate groups add up to 96(this can be changed), validate!
If Group1 + Group2 + Group3 + Group4 = 96 Then
Label_FinalVal.ForeColor = Color.Green
Label_FinalVal.Text = "Validated"
'---------- my.settings.ValidationCheckSetting=true
Else
Label_FinalVal.ForeColor = Color.Red
Label_FinalVal.Text = "Invalid Key"
End If
Else
Label_GroupD_Val.Text = "Bad"
End If
Else
Label_GroupC_Val.Text = "Bad"
End If
Else
Label_GroupB_Val.Text = "Bad"
End If
Else
Label_GroupA_Val.Text = "Bad"
End If
'---^^^^^^^^^^^^^^^^^^^^ END OF TO TAKE OUT ^^^^^^^^^^^^^^^^^--
Else
Label_FinalVal.Text = "Key is not valid, check key for spaces."
End If
Else
Label_FinalVal.Text = "Key is not valid, please check the key and try again"
End If
End Sub
End Class
