PSU faulty?
46 (0.03/day)
My PC has just started to play up. I go to hit the power button, PC power LED lights up, I hear a 'click', then it powers down. If I hit the power button repeatedly like 3 or 4 times, PC will fire up and boot.
Is my PSU about to go? It's not a cheapie - Seasonic Focus 650W. I have other supplies, so may need to test them out.
Thanks.
If you are OCing... set it back to normal and try it.
Or, it could be PSU, Motherboard, memory, etc.
Process of elimination... try different psu, try with one stick of memory (try one, then try with another). Any lights or beeps from motherboard?
When you get it running, check device manager to see if any devices are acting up.
It would help if you listed your system specs.
Nah, not overclocking. If anything, I've set the speed in BIOS to 3.6GHz. I did this to control CPU temp when crunching.
Running Linux Mint 20, so no Device Manager.
Specs:
System: Host: ryzen7 Kernel: 5.4.0-53-generic x86_64 bits: 64 Desktop: Cinnamon 4.6.7 Distro: Linux Mint 20 Ulyana
Machine: Type: Desktop System: Gigabyte product: B450M DS3H v: N/A serial: <superuser/root required>
Mobo: Gigabyte model: B450M DS3H-CF v: x.x serial: <superuser/root required> UEFI [Legacy]: American Megatrends
v: F51 date: 07/29/2020
CPU: Topology: 8-Core model: AMD Ryzen 7 2700X bits: 64 type: MT MCP L2 cache: 4096 KiB
Speed: 3508 MHz min/max: N/A Core speeds (MHz): 1: 3508 2: 3533 3: 3687 4: 3692 5: 3679 6: 3674 7: 3681 8: 3693
9: 3678 10: 3533 11: 3687 12: 3691 13: 3679 14: 3674 15: 3680 16: 3692
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] driver: amdgpu
v: kernel
Display: x11 server: X.Org 1.20.8 driver: amdgpu,ati unloaded: fbdev,modesetting,radeon,vesa
resolution: 3840x2160~60Hz, 1920x1080~60Hz
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.35.0 5.4.0-53-generic LLVM 11.0.0)
v: 4.6 Mesa 21.0.0-devel (git-e9caba6 2020-11-11 focal-oibaf-ppa)
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel
Device-3: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound Server: ALSA v: k5.4.0-53-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: b4:2e:99:8f:82:e5
Drives: Local Storage: total: 9.78 TiB used: 2.05 TiB (21.0%)
ID-1: /dev/nvme0n1 vendor: Silicon Power model: SPCC M.2 PCIE SSD size: 238.47 GiB
ID-2: /dev/sda vendor: Seagate model: ST4000DX001-1CE168 size: 3.64 TiB
ID-3: /dev/sdb vendor: Western Digital model: WD5000AAKX-001CA0 size: 465.76 GiB
ID-4: /dev/sdc vendor: Western Digital model: WD60PURX-78T0ZY1 size: 5.46 TiB
Partition: ID-1: / size: 233.73 GiB used: 54.23 GiB (23.2%) fs: ext4 dev: /dev/nvme0n1p1
Sensors: System Temperatures: cpu: 65.5 C mobo: N/A gpu: amdgpu temp: 58 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
Info: Processes: 376 Uptime: 1h 04m Memory: 31.37 GiB used: 7.63 GiB (24.3%) Shell: bash inxi: 3.0.38
