System Name | Silent/X1 Yoga/S25U-1TB |
Processor | Ryzen 9800X3D @ 5.4ghz AC 1.18 V, TG AM5 High Performance Heatspreader/1185 G7/Snapdragon 8 Elite |
Motherboard | ASUS ROG Strix X870-I, chipset fans replaced with Noctua A14x25 G2 |
Cooling | Optimus Block, HWLabs Copper 240/40 x2, D5/Res, 4x Noctua A12x25, 1x A14G2, Conductonaut Extreme |
Memory | 64 GB Dominator Titanium White 6000 MT, 130 ns tRFC, active cooled, TG Putty Pro |
Video Card(s) | RTX 3080 Ti Founders Edition, Conductonaut Extreme, 40 W/mK 3D Graphite pads, Corsair XG7 Waterblock |
Storage | Intel Optane DC P1600X 118 GB, Samsung 990 Pro 2 TB |
Display(s) | 34" 240 Hz 3440x1440 34GS95Q LG MLA+ W-OLED, 31.5" 165 Hz 1440P NanoIPS Ultragear, MX900 dual VESA |
Case | Sliger SM570 CNC Alu 13-Litre, 3D printed feet, TG Minuspad Extreme, LINKUP Ultra PCIe 4.0 x16 White |
Audio Device(s) | Audeze Maxwell Ultraviolet w/upgrade pads & Leather LCD headband, Galaxy Buds 3 Pro, Razer Nommo Pro |
Power Supply | SF1000 Plat, 13 A transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua |
Mouse | Razer Viper V3 Pro 8 KHz Mercury White w/Pulsar Supergrip tape, Razer Atlas, Razer Strider Chroma |
Keyboard | Wooting 60HE+ module, TOFU-R CNC Alu/Brass, SS Prismcaps W+Jellykey, LekkerL60 V2, TLabs Leath/Suede |
Software | Windows 11 IoT Enterprise LTSC 24H2 |
Benchmark Scores | Legendary |
Processor | AMD Ryzen 5 5600@80W |
Motherboard | MSI B550 Tomahawk |
Cooling | ZALMAN CNPS9X OPTIMA |
Memory | 2*8GB PATRIOT PVS416G400C9K@3733MT_C16 |
Video Card(s) | Sapphire Radeon RX 6750 XT Pulse 12GB |
Storage | Sandisk SSD 128GB, Kingston A2000 NVMe 1TB, Samsung F1 1TB, WD Black 10TB |
Display(s) | AOC 27G2U/BK IPS 144Hz |
Case | SHARKOON M25-W 7.1 BLACK |
Audio Device(s) | Realtek 7.1 onboard |
Power Supply | Seasonic Core GC 500W |
Mouse | Sharkoon SHARK Force Black |
Keyboard | Trust GXT280 |
Software | Win 7 Ultimate 64bit/Win 10 pro 64bit/Manjaro Linux |
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality Fractal Design Define R4 case, 2 x FD 140mm fans, CM Hyper 212 EVO HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
Add to that, generally software readings when it comes to PSU rails can be completely wrong and if you have an issue that might be PSU related the only reliable way to measure those rails is with a HW multimeter, I've seen some crazy values in software that were completely false, not sure why they still present these values in SW tbhAccording to the ATX Form Factor standard, PSUs must maintain voltage tolerances within ±5% of required specifications.
Acceptable tolerance maximums:
12VDC ±5% = 11.4 to 12.6VDC5VDC ±5% = 4.75 to 5.25VDC3.3VDC ±5% = 3.14 to 3.47VDC
Me too. In fact, the popular HW info program, Speccy from the makers of CCleaner used to show the values for the +12V, +5V, and +3.3VDC voltages but so often were way off. For example, for the board in the computer I am using now, it used to report my +12VDC was measuring about 6.7V and my +5V was showing around 2V. If those were true, the computer would not be running. This happened so often that they removed the feature from Speecy.I've seen some crazy values in software that were completely false
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
If the 12V, 5V, 3.3V are under or over 5% (4.99%- or 5.01%+) you should be concerned at that point.Current Set up
Msi B550 Gaming Plus motherboard
Crucial Mx500 1 tb
500gb SSD
Gigabyte Rtx 3060 Eagle
R5 5900x aio cooled cooler master ml240
Corsair RMx 750x
Just wanted to share my readings from HWINFO checking system for stability.
System Name | AlderLake |
Processor | Intel i7 12700K P-Cores @ 5Ghz |
Motherboard | Gigabyte Z690 Aorus Master |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p |
Case | Be quiet! Silent Base 600 - Window |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W |
Mouse | Logitech MX Anywhere 2 Laser wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless |
Software | Windows 11 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
If you're only getting 11.4V on the +12V line how much does that affect your fans? How much slower do they run at 11.4V as opposed to 12V?
System Name | daily driver Mac mini M2 Pro |
Processor | Apple proprietary M2 Pro (6 p-cores, 4 e-cores) |
Motherboard | Apple proprietary |
Cooling | Apple proprietary |
Memory | Apple proprietary 16GB LPDDR5 unified memory |
Video Card(s) | Apple proprietary M2 Pro (16-core GPU) |
Storage | Apple proprietary onboard 512GB SSD + various external HDDs |
Display(s) | LG UltraFine 27UL850W (4K@60Hz IPS) |
Case | Apple proprietary |
Audio Device(s) | Apple proprietary |
Power Supply | Apple proprietary |
Mouse | Apple Magic Trackpad 2 |
Keyboard | Keychron K1 tenkeyless (Gateron Reds) |
VR HMD | Oculus Rift S (hosted on a different PC) |
Software | macOS Sonoma 14.7 |
Benchmark Scores | (My Windows daily driver is a Beelink Mini S12 Pro. I'm not interested in benchmarking.) |
The best person to answer this is you.If you're only getting 11.4V on the +12V line how much does that affect your fans? How much slower do they run at 11.4V as opposed to 12V?
Clearly you have a different philosophy on the operation of fans in your PC case.The only fans that I have that would probably be affected by less than 12V are ones that you can't connect to motherboard headers (i.e. they draw far too much current [especially on start-up]).
I rather get the +12V I paid for than something less than that.
Atx spec allows for tolerance and sometimes mobo sensors are trash, best to check volts on the psu using a DMMThe only fans that I have that would probably be affected by less than 12V are ones that you can't connect to motherboard headers (i.e. they draw far too much current [especially on start-up]).
For giggles, I played with this for a few minutes on my daily driver PC.If you're only getting 11.4V on the +12V line how much does that affect your fans? How much slower do they run at 11.4V as opposed to 12V?
Processor | Threadripper 3955WX |
Motherboard | M12SWA-TF |
Cooling | Arctic Freezer 4U SP3 |
Memory | G.Skill Trident Z DDR4-3733 (2x8GB) |
Video Card(s) | 5700XT + 3x RX 590 |
Storage | A lot |
Display(s) | ViewSonic G225fB |
Case | Corsair 760T |
Audio Device(s) | Sound Blaster Z SE |
Power Supply | be quiet! DPP12 1500W |
Keyboard | IBM F122 |
Software | 10 LTSC |
*hides 38mm Deltas and jap Sunons* y-yeah, hehFor me having to use noisy high-speed fans would indicate a flawed build design from a holistic perspective (acoustics, power/environment, money).
Let me guess, a fellow AMD userThe Noctua i-PPC fans are weak sauce in comparison to the industrial 127x38mm and 127x50mm fans I use, which both have a maximum air flow of between 179.75CFM to 200 CFM and draw 2.7A+. They're only on when I need to cool my videocard.
Noctua is overrated*hides 38mm Deltas and jap Sunons* y-yeah, heh
Most of these "non-consumer grade" fans work fine in the 5-14V range. I went for these because I already had them but also because I didn't want my new PC to overheat, I've never liked auto fan speed or curves except for the CPU so I hooked up the rest to a bunch of 3P switches to manually control the speed or turn them off.
Noctua stuff isn't actually industrial they just call their fans that way so users think they're better than the standard ones, but hey they have to milk those juicy gamers' wallets somehow.
I’m okay with that.Noctua is overrated
LOLNoctua is overrated
