Pundit-R's (Barebone) GPU = RS300? and DVI Problem
xrmb
1 (0.00/day)
I tried to use the ATI Tool with my onboard RS300 (or 9100 IGP), it says not supported. I also looked in the GPU database, and there the 9100 IGP shows up as RC350 or RS350. What did Asus put on my board? Something new?
Ok, the main problem that I have is not the ATI Tool. It's that I can't use the onboard graphic and DVI output with my Optoma projector, the DVI always stays disabled when I boot with it. If I put the DVI cable in my Samsung LCD, boot then, change to cable to the projector while the PC is running it works fine. I'm not sure who's problem it is, the projectors or the gpu's. Maybe someone here knows a way how to enable the DVI in windows, or maybe there is something in the BIOS I can do, or Firmware hack :)
I'm open for everything, and I think here are some guys with good ideas... thanks in advance
