Q9550 on UD3P: Help me overclock more or fine tune my current OC.
-Spanky-
135 (0.02/day)
In my bunker complex, well below the Saskatchewan
System Name Go here for updated specs & more info: http://natescomp.com/?page_id=7
Processor AMD 1090T
Motherboard Gigabyte 890FXA-UD5
Cooling 5x 80mm Case Fans, 120x38mm Delta on CPU
Memory 2x4GB G.Skill DDR3 @ 1720MHz
Video Card(s) EVGA GTX 275 720/1476/1260MHz
Storage 2x 1TB Samsung HD103SJ in RAID0
Display(s) 1x Acer AL2016W & a 22"
Case Chieftec Alumnium Dragon
Audio Device(s) Audio-GD NFB-12 > Sony 55ES Amp > JBL L19A Speakers
Power Supply Corsair AX850
Benchmark Scores Not into benchmarking.
Title pretty much says it all. Below is my template that I've been running for a while and when I first loaded it up it was stable and I haven't had any BSOD's or freezing on it. I would like to have a higher FSB or memory if possible and if not, at least a fine tune on what I am running would be nice. I'm not really looking for a much higher CPU clock since I just don't need it but a little wouldn't hurt, even a downclock wouldn't hurt either. I do love this board but all the options just create a huge headache. I have spent hours trying to improve what I have and sometimes I can get into Windows but will freeze while running OCCT, other times I'm not so lucky. If you can help me improve it I would appreciate it.
I know there's a lot of Auto but it works and if I knew everything, I wouldn't ask for help :)
Code:
******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 7 ]
Fine CPU Clock Ratio............................[ + 0.5 ]
CPU Frequency 3.37GHz...........................[ 450 x 7.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 450 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.................................................... [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 700mv ]
PCI Express Clock Drive.........................[ 700mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance.............................[Standard]
(G) MCH Frequency Latch.........................[ 333MHz]
System Memory Multipler.........................[ 2.40B]
Memory Frequency 1066...........................[ 1080]
DRAM Timing Selectable..........................[ Manual]
CAS Latency Time................................[ 5]
tRCD............................................[ 5]
tRP.............................................[ 5]
tRAS............................................[ 12 ]
******Advanced Timing Control******
tRRD............................................[ Auto ]
tWTR............................................[ Auto ]
tWR.............................................[ Auto ]
tRFC............................................[ Auto ]
tRTP............................................[ Auto ]
Command Rate (cmd)..............................[ Auto ]
******Channel A Timing Settings******
Static tRead Value  ...............[ Auto ]
tRD Phase0 Adjustment ................[ Auto ]
tRD Phase1 Adjustment  ................[ Auto ]
tRD Phase2 Adjustment  ................[ Auto ]
tRD Phase3 Adjustment  ................[ Auto ]
tRD 2rd (Differnt Rank)  ................[ Auto ]
tWR 2wr (Differnt Rank)  ................[ Auto ]
tWR 2rd (Differnt Rank)  ................[ Auto ]
tRD 2wr (Same/Difft Rank) ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
tRD 2wr (Same/Difft Rank)................[ Auto ]
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Disable ]
CPU Vcore [ 1.25]..............................[ 1.25V ]
CPU Termination [ 1.20 ]...................[ Auto ]
CPU PLL [ 1.50 ]...................[ Auto ]
CPU Reference [ 0.760 ]...................[ Auto ]
MCH Core [ 1.100 ]...................[ 1.16V]
MCH Reference [ 0.760 ]...................[ Auto ]
MCH/DRAM Refernce [ 0.900 ]...................[Auto ]
ICH I/O [ 1.500 ]...................[ Auto ]
ICH Core [ 1.100 ]...................[ Auto ]
DRAM Voltage [ 1.800 ]...................[ 2.060V]
DRAM Termination [ 0.900 ]...................[Auto]
Channel A Ref [ 0.900 ]...................[Auto]
Channel B Ref [ 0.900 ]...................[Auto]
I would throw some more vcore at it and lower ram divider. 450mhz was the top end of stability on my 780i board. In a couple of days I will have my 9550/UD3P and I will be able to go into more detail on this subject.
Not to sound ungrateful Buck Nasty but I'm not sure what that would do for me? My main goal isn't a higher CPU clock, but higher FSB or memory or if nothing else, better timings. I have POST'ed at 1120MHz for the RAM and on another occasion have POST'ed at 500MHz FSB so there's gotta be a way with voltages and whatnot, I'm just stuck and annoyed. There really isn't a time where I use 100% of all the cores (or 100% on any core for older apps) but I do notice that the load times for games and such aren't hindered by the CPU or hard drive so while the improvements may be minimal, I'm guessing a higher FSB or memory clock or better timings might help. I'm sure there will be a time not too far from now where I'll want to get close to that 4GHz mark and it would be nice to be able to just up the vcore and multiplier. Anyway, I look forward to your advice :)
Bump for a little expertise?
