Question about having two cpu's
2,452 (0.40/day)
System Name Dell Workstation t5810
Processor Xeon CPU's E5-2683 v4 Broadwell-E Technology
Motherboard Broadwell-E X99
Cooling Default fan System Level 3
Memory 48GB DDR4
Video Card(s) Radeon Pro VII 16GB
Storage 2 Internal SSD, 6 External HDD
Display(s) Dell 27 Inch Monitor
Case Dell Precision 5810
Audio Device(s) RealTek High Definition
Power Supply 825 Watts PSU
Mouse Soundless Black Quiet Mouse
Keyboard Dell Black
Software Windows Pro 10 x64
I'm upgrading my rig soon to a computer that has 2 cpu's slots, and was curious do i have to match up with the same 2 cpus or can you mix them up? (using the same Version , just different processors) I am currenting using a 2678 v3.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
They have to be the same processor.
114 (0.03/day)
And more than this, would be very nice (to not say highly recommended OR even mandatory in some "picky" motherboards cases) to be "matched pair" (same batch)
Mussels
Freshwater Moderator
58,412 (7.77/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Feels like i havent seen you post in ages, aloha etc
IME, they gotta be matched
Low quality post by Bill_Bright
13,956 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
114 (0.03/day)
Not mandatory, depend by platform (for example on 1366 ive "matched" without any problem various batch CPUs (ofc, identical), on 2011 and 2011-3 i had problems sometimes. (I couldnt "charge" the mobo in itself or the "platform" (chipset) about this :))
2,540 (0.47/day)
You making a stream pc encoder setup because that is how you make a stream pc encoder setup ?
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Seem suggesting, or perhaps it was the way I suggested, you read the manual was considered "Low quality". Not sure why since the acronym has been widely used on this site and across the industry (many industries, actually) for decades. But, if it offended anyone, I apologize. That said, considering the actual language (not acronyms) so often used and allowed on this site, again, not sure why it would offend anyone - but again, I apologize.
Regardless, my advice stands. I would urge you check the user manual for your motherboard. If you don't have it, you typically can download the latest revision from the motherboard's webpage. If not then, then the maker's tech support.
2,452 (0.40/day)
Memory 48GB DDR4
Keyboard Dell Black
Hello. I'm always posting every now and then. Probably post a bit more on guru3d though lately, but I'm still here. Techpowerup is the best forum to get the best advice and quicker responses. Try posting on the AMD forums, you will be waiting for months for a reply lol. I hate that site.
Gaming, etc. The best desktop i found that has 2x cpu slots is the Dell Precision 7810. I'm using a 5810 right now w/ Intel 2678 v3, w5500 8GB , that would be secondary rig soon(using my wx 7100 with that) once i get the 7810 with 2 decent cpus. w/ my w5500.
2,540 (0.47/day)
You might need two seperate operating systems because one's dram access will influence the other and you don't want the online computer to stall at the encode latency. Maybe a dual hypervisor dual os setup.
PS: I'm noob, don't be too critical.
Toothless
Tech, Games, and TPU!
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Got got a buddy that games on a 2687v2 and it's meh. You're better off going at least X79/1680v2 if you want to game on a Xeon. The clockspeeds are the big limiters, not core counts.
Unless you're doing something with multiple game clients, which against nearly all TOS, then sure.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Modern operating systems are Numa node aware. If you run a program that doesn't know how to deal with multiple processors/RAM domains, the Windows is pretty good at keeping that program on one Numa node so it doesn't stall out waiting on communication between nodes.
2,540 (0.47/day)
Color me blind, but an operating system keeps the same schedule between different operations and that impacts the latency of real time gaming performance. If you want to keep seperate tabs, you need a whole seperate software chain from the motherboard to the os. However, if you don't care gaming at the encoding latency(I dunno if you are into lag hacking for unfair competitive advantage), you might as well use a single cpu motherboard, threadripper and such.
30,553 (7.07/day)
This. Additionally it's a good ideal to make sure the CPU model you choose also has matched stepping codes. Having the same CPU model but different steppings can result in system instability that will leave you pulling your hair out in frustration.
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
Yeah, for the best compatibility and stability, I'd with CPUs which are not just identical, but have the same stepping.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
Seems to me, "identical" means just that, "identical". For sure, it is important to ensure the stepping number (or letter, or alpha-numeric version) is the same, but isn't that implied?
I'm just saying, if I see model 2487a, I am not going to assume it is "identical" to 2487b.
Mussels
58,412 (7.77/day)
Oystralia
As an example, back in the days the Q6600 came in G0 and B3 steppings, despite being the same model CPU - and they had differences
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Exactly, for hobbyists, the G0 was a better overclocker. The same happened with Phenom II C2 and C3 steppings.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Windows schedules the process for what CPU to use and when. If a program is not Numa node aware, Windows will keep it scheduled on a single CPU/RAM. If you are recording gameplay, it does not matter that the recording process and the game process are on different Numa nodes, this will not add latency. The screen recording is pulling from the VRAM framebuffer, not the game process.
2,004 (0.55/day)
Seattle, WA
There's a lot of random tidbits of info being thrown around here that don't answer the question.
Just match the CPU model for both. If you're getting an E5-2687W v4, get two. Don't mix models, and don't worry about matching anything but the model number.
Errata stepping on modern Xeons is uncommon. If Intel has issued a new stepping within the same model it will be specifically listed as such.
30,553 (7.07/day)
Incorrect. Steppings matter! Always have. Please review;
Model numbers have to match, stepping codes have to match, batch numbers do NOT.
2,452 (0.40/day)
Memory 48GB DDR4
Keyboard Dell Black
I have a 2678 v3 and i game perfectly fine, 1080p pretty much 50-60fps(97%) in all my games. I have no problems playing any game that's out. So I'm not sure why you say its meh.
13,956 (2.04/day)
Nebraska, USA
Mouse Logitech M190
I understand that. And I am not disputing or questioning that. I am just saying that if one is G0 and the other is B3, then clearly they were NOT "identical"! They were very similar, and certainly in the same family, but they were not identical.
If the user did his or her homework - as they should - and thoroughly researched the data, they would have easily seen the difference. And for sure, if someone is building a dual-processor system, they likely are not total noobs - but if they are and don't know enough (or are too egotistical) to research and do their homework first, then they have no business working this project, IMO.
This is nothing new or unique to processors either. For example, when a controller board dies on a hard drive, you cannot just replace the board from any drive from the same maker and model number and expect the drive to work. You have to ensure the revision number is the same too. Or else, you might get a newer one from Taiwan when you really need the older revision that came from Malaysia. Exact same model numbers but NOT "identical".
When looking to flash the BIOS on a motherboard, ensuring the same model number is not good enough. You must ensure you have the right motherboard revision number too. Same model, but not identical.
^^^THIS^^^ And I believe anyone who has built a dual (or quad) processor system should already understand two (or four) processors with the same model number may not be identical.
Way WAY back in the day I was supporting hardware in a major software development company for a big DoD secure network. We were building new quad-core servers with Supermicro boards. We not only had to ensure the processors had the "identical" stepping number, we made sure each set came from the same manufacturing "Lot" number too. Fortunately, these days, motherboards are much more tolerant to slight differences, and processor manufacturers are much better at ensuring consistency and compliance to specs. So ensuring the same lot number is not necessary.
Again, I am just saying, identical means identical - not "almost" the same. And maybe I'm totally wrong, but it is my experience that anyone with experience in this area already knows that. And if new to this area (either professionally or as a hobby enthusiasts), they should know to do the research before spending their $$$, or committing someone else's $$$. That was drilled into me when I first started building dual and quad processor systems. And I drilled that into the junior techs when they started building them.
So back to my original question - isn't it implied that "identical" means the same stepping number too? It does to me.
Toothless
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Yes, it does work, but that doesn't always mean it's favorable for that task. If it's not thread limits it's just speed limited. Done those tests on my own Xeon builds and it's the same thing across the board.
Yes it runs, just "good enough" though.
