Question IEMs In-Ears headphone
tiagnan
7 (1.00/day)
1) I have the KZ EDX Pro and KZ EDC Pro models. If I store them for a long time near electronics such as a 29" CRT TV and HDD, will there be magnetic disturbances between the dual magnetic dynamic driver and the magnetism of the 29" CRT TV and HDD? Will this cause the demagnetization of the in-ear drivers?
2) I believe that the eartips of these two KZ models are made of silicone. If I store silicone eartips for many years, could they undergo chemical degradation and melt and stick to the body of the IEMs?
Very strange question. Potentially yes, but this would be very slight.....I'd be more worried about the damage they might cause to the hard drives or TV, rather than the other way around. They are tiny, so why not just put them somewhere else? Problem solved.
As for the ear tips, they might get a bit degraded over time.....but it will be years. Chances are the will just get crusty and brittle, but could stick a bit. A little dab of iso alcohol and a clean, soft cloth will take care of that. Again......just remove the tips. Problem solved.
Is it possible to store In-Ears IEMs without use for many years? Does the time of no use cause permanent damage and die to the dual magnetic dynamic drivers?
IEMs with dual magnetic dynamic drivers like the KZ EDX Pro and KZ EDC Pro over long-term storage of years do the diaphragm lose frequency performance and generate distortions? In my case 34-36C 59-70% RH
They haven't existed for many years, so no one knows. They will probably be fine, but you can test it and find out first hand.
If you aren't going to use them, why did you buy them?
