Question not a Problem - Display after power outage
816 (0.20/day)
South Africa
System Name Mroofie / Mroofie
Processor Inte Cpu i5 4460 3.2GHZ Turbo Boost 3.4
Motherboard Gigabyte B85M-HD3
Cooling Stock Cooling
Memory Apacer DDR3 1333mhz (4GB) / Adata DDR3 1600Mhz(8GB) CL11
Video Card(s) Gigabyte Gtx 960 WF
Storage Seagate 1TB / Seagate 80GB / Seagate 1TB (another one)
Display(s) Philips LED 24 Inch 1080p 60Hz
Case Zalman T4
Audio Device(s) Meh
Power Supply Antec Truepower Classic 750W 80 Plus Gold
Mouse Meh
Keyboard Meh
VR HMD Meh
Benchmark Scores Meh
Display shows nothing but everything is running (After Power outage)
Usually fixed by turning off power supply and pulling the cable as well.
Can this be considered normal procedure after such event?
I know some "state" could be saved but im just worried that the gpu is going bad.
Rei
656 (0.38/day)
Guam
System Name 1 Desktop/2 Laptops/1 Netbook
Processor AMD Athon X2 64/Intel Pentium 997/Intel Pentium 4/Intel Atom
Motherboard EpoX ATX motherboard/Samsung/Toshiba/Lenovo
Cooling Stock
Memory 4 GB/4 GB/2 GB/2 GB
Video Card(s) Asus GeForce GTX 780 Ti/Intel HD Graphics/GeForce 4MX/Intel GMA
Storage 6+ TB Total
Display(s) HP Pavilion 14 Inch 1024x768@60Hz 4:3 Aspect Ratio CRT Monitor
Case None
Audio Device(s) Various
Power Supply Seasonic 500 Watt & VenomRX 500 Watt
Mouse Wayes Iron Man Wireless Mouse
Keyboard Rexus VR2 Wireless Keyboard
Software Win10 & WinXP SP3
Benchmark Scores It sucks...
Unlikely...
Just curious, is this a normal occurrence to you? Is everything running normally after your "fix"?
816 (0.20/day)
South Africa
Case Zalman T4
Audio Device(s) Meh
Mouse Meh
Keyboard Meh
VR HMD Meh
Unlikely...
1. Only after a power outage
2. for the most part yes
Rei
656 (0.38/day)
Guam
Cooling Stock
Storage 6+ TB Total
Case None
In the long run, it could be hazardous to your hardware & even your sanity if you lost work/progress when power outage strikes. It could be your power supply acting weird. My recommendation is to get an Uninterruptible Power Supply as a backup battery during outages. Otherwise get another better power supply unit but this might be a costly move as you shouldn't cheap out on the power supply unit to ensure it doesn't fry your other hardware. What power supply are you using anyway? Is it that standard 450W or the Antec 750W listed in your spec sheet?
2,758 (0.66/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
The monitor could be defaulting when power is cut to a default input selection such as HDMI or DVI as examples of it.
Most monitors can use more than one input source, selectable in the menu or by a button on the monitor itself. Based on what you are using the monitor will have to be set for the correct input type and with many monitors the correct "Port" such as HDMI 1 or HDMI 2, depends on what input port to the monitor you are using.
Most monitors will hold the setting used but could be yours is just defaulting everytime it loses power.
816 (0.20/day)
South Africa
Case Zalman T4
Audio Device(s) Meh
Mouse Meh
Keyboard Meh
VR HMD Meh
My thoughts as well
693 (0.41/day)
Greece
System Name Office / HP Prodesk 490 G3 MT (ex-office)
Processor Intel 13700 (90° limit) / Intel i7-6700
Motherboard Asus TUF Gaming H770 Pro / HP 805F H170
Cooling Noctua NH-U14S / Stock
Memory G. Skill Trident XMP 2x16gb DDR5 6400MHz cl32 / Samsung 2x8gb 2133MHz DDR4
Video Card(s) Asus RTX 3060 Ti Dual OC GDDR6X / Zotac GTX 1650 GDDR6 OC
Storage Samsung 2tb 980 PRO MZ / Samsung SSD 1TB 860 EVO + WD blue HDD 1TB (WD10EZEX)
Display(s) Eizo FlexScan EV2455 - 1920x1200 / Panasonic TX-32LS490E 32'' LED 1920x1080
Case Nanoxia Deep Silence 8 Pro / HP microtower
Audio Device(s) On board
Power Supply Seasonic Prime PX750 / OEM 300W bronze
Mouse MS cheap wired / Logitech cheap wired m90
Keyboard MS cheap wired / HP cheap wired
Software W11 / W7 Pro ->10 Pro
Check another monitor and/or tv. If the issue replicates, I would consider it as a problem or at least a warning sign.
13,942 (2.04/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
On what? The monitor or the computer? It may be necessary to do it on both. As Bones suggested, the monitor could be reverting back to some default input. But also, the graphics solution could be reverting back to some unsupported setting too and what may be happening is simply that the graphics solution and the monitor are no longer in sync. They need to reestablish "handshaking". Hence a total "cold" reboot. And by "cold" I mean shut down the computer and flip the master power switch on the back of the power supply (if your supply has one) to off (or “0”) or unplug the power supply from the wall for about 15 seconds. Then turn the master power switch to on (or “1”) or reconnect power and boot up and see what happens. By totally removing power, you remove the +5Vsb standby voltage all ATX Form Factor power supplies are required to supply whenever the power supply is plugged into the wall and (if applicable) the master power switch is set to on. This standby voltage is distributed throughout several points on the motherboard, including RAM for faster boots and the USB ports too. This also keeps alive several features, including “wake on keyboard” and “wake on mouse”, and the network interface for “Wake on LAN” commands. A cold reboot ensures any device settings that may be held by the standby voltage are released, then reset when power is restored.
I also emphatically second Rei's suggestion to put your computer on a "good" UPS with AVR. It is actually the AVR (automatic voltage regulation) that makes a "good" UPS so important and that feature alone may prevent many of your unexpected shutdowns if those power anomalies are just short fluctuations (as most are) instead of full outages. Typically, battery backup during a full outage is just a nice bonus feature.
When you say this problem is "usually fixed", I get the impression this is a common occurrence. All the more reason to get a "good" UPS. Note I keep saying "good" UPS with AVR. Like power supplies, there are cheap, good, and best. The best are very expensive at $400 or more, and not needed for most users. The cheap are just that, cheap and should be avoided. The ATX Form Factor standard requires all PSUs "hold" voltages for a mere 17ms (milliseconds) during abnormal power events. A "good" UPS can react easily within that time frame.
Note surge and spike protectors are little more than fancy and expensive extension cords as they do nothing for low voltage events like dips (opposite of spikes), sags (opposite of surges) or brownouts (long duration sags) - not to mention full power outages. And for excessive surges and spikes, they simply shut off power (if working properly), crashing your computer - never good.
I have an APC 1500VA UPS on this system, and it supports my computer, all my network gear and "two" 24" monitors. It will easily run this system for 45 minutes should I lose power. If I quickly shut down my computer and turn off both monitors, it will keep my network alive for more than 4 hours. That means I can still access the Internet with my notebook or smartphone.
Last, you might want to get yourself a AC Outlet Tester to ensure the wall outlet is properly wired and grounded to Earth ground. I recommend one with a GFCI (ground fault circuit interrupt) indicator as it can be used to test bathroom and kitchen outlets (outlets near water) too. These testers can be found for your type and voltage outlet, foreign or domestic, (like this one for the UK) at most home improvement stores, or even the electrical department at Wal-Mart. Use it to test all the outlets in the home and if a fault is shown, have it fixed by a qualified electrician.
  • Like
Reactions: Rei
816 (0.20/day)
South Africa
Case Zalman T4
Audio Device(s) Meh
Mouse Meh
Keyboard Meh
VR HMD Meh
Playing prey and just and got a complete lock.
Pressed restart and got no video input & enter sleep mode display error
back again also had ms update in background :wtf:
