- Jan 19, 2017
- 400 (0.13/day)
System Name | Core p90 |
Processor | I7 9700k |
Motherboard | ASRock Z390 Phantom Gaming 4 |
Cooling | Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo. |
Memory | Trident gskill 4x8gb 3000mhz (temporarily running 2x 32gb ddr4 corsair vengeance 3600mhz) |
Video Card(s) | Nvidia Founders edition rtx 3080 10gb |
Storage | M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd |
Display(s) | Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor |
Case | Thermaltake Core P90 tempered glass edition |
Audio Device(s) | On board |
Power Supply | Thermaltake smart m1200w |
Mouse | Razer Basilisk v3 |
Keyboard | Logitech G910 |
Software | Windows 10 64bit |
I'm completly new to the new features in the nvidia control panel and in-game overlay.
I'm talking about "image sharpening, filters, gpu scaling, ignore film grain etc..."
In the past I've always done some minimal nvidia 3d settings tweaks (like turning on Vsync, playing with aa and stuff)
AND I'd use reshade (or sweetfx back in the day) to apply shaders and or sharpening...
My friend tells me that Nvidia incorporated a lot of this in their panel and overlay... I tried it and I'm quite pleased with it. Nvidia shadowplay was a nice discovery for me as well. Now here is where I'm confused:
- Should I use Nvidia's "gpu scaling" (SQUARE tick box) option in the control panel (image sharpening) OR should I use DLSS or BOTH?
- (The more I read about it the more it sounds a WHOLE LOT like DLSS) lower my resolution to then add sharpening and upscaling algorithms to increase performance without losing too much graphic fidelity.
- Should I use the CONTROL PANEL version of "image sharpen" OR the SAME filter found in the "overlay" called "sharpen"?
- (which can be adjusted on the fly rather than having to go to the nvidia panel everytime)
- I'm running on a 3440x1440 ultrawide monitor, should I use the "ultra performance preset" OR "performance" preset for DLSS?
- Have you guys adopted Nvidia's "filters" from the overlay or are you still running Reshade instead?
- What would be a good "usage scenario" for DSR?
- (Isn't applying filters, reshades and sharpening more than enough? What's the point of using DSR?) I NEVER really used DSR...
