Quick Case Question
187 (0.11/day)
Do they sell replacement cover tabs for cases? the cover tabs that you remove when you want to put in a videocard for exsample? I accidently threw 2 of them out when I moved (pretty sure) and was just wondering if there was a way to get replacements if the case company sells them or theres a vendor that makes them on a case by case basis?
Ah, slot covers. I'd ask from the customer support of your case's manufacturer.
Since a slot is pretty much standard you can buy generic ones that'll do the job... they may not match the design of your current ones, unless you replace all of them :)
if you ask from the same case i guess not, just buy from the market places
just search "pci cover"
newegg, amazon, etc., all sell replacement PCI slot covers
