Quick Q: Do i need to connect 1 or both cpu cables from my RM850x to my Z690 Gaming X motherboard?
649 (0.11/day)
Norway, which means Amazon is not available...
System Name Winter v3.2024
Processor Intel i7 12700K (since november 2021)
Motherboard Gigabyte Z690 Gaming X (since november 2021)
Cooling Air Liquid Freezer II 360 with LGA1700 kit (since november 2021)
Memory Crucial Ballistix 2x16gb 3600mhz C16 (since november 2021)
Video Card(s) Gigabyte RTX 3060 Ti Gaming OC Pro LHR - Rev3.0 (since july 2022)
Storage 1x 1TB WD Blue SN570 SSD, 1x Seagate 4TB SATA
Display(s) 1x 55" LG C1 4k OLED, 1x Gigabyte 32" M32Q and 2x AOC 27" CG1
Case Fractal Design Define R6 (since 2018 and still working like a charm!)
Power Supply Corsair RM850x black (since august 2022)
Mouse Razor Deathadder v2 (since december 2021)
Keyboard Varmilo VEA109 v2 MX Silent Red (since august 2022)
I have the Gigabyte z690 gaming x mobo + a new rm850x, but i don't know if i should connect BOTH cpu cables from the psu to the mobo or just 1... Any ideas on that?
Yes, i am going to swap my current psu (550w) with the rm850x.
I honestly tried googling it, but i couldn't find a clear answer (since i am a beginner in the world of pc building)...
8,570 (1.81/day)
Ovronnaz, Wallis, Switzerland
System Name main/SFFHTPCARGH!(tm)/Xiaomi Mi TV Stick/Samsung Galaxy S25/Ally
Processor Ryzen 7 5800X3D/i7-3770/S905X/Snapdragon 8 Elite/Ryzen Z1 Extreme
Memory 64gb DDR4 3600/8gb DDR3 1600/2gbLPDDR3/12gbLPDDR5x/16gb(10 sys)LPDDR5 6400
Video Card(s) Hellhound Spectral White RX 7900 XTX 24gb/GT 730/Mali 450MP5/Adreno 830/Radeon 780M 6gb LPDDR5
Storage 250gb870EVO/500gb860EVO/2tbSandisk/NVMe2tb+1tb/4tbextreme V2/1TB Arion/500gb/8gb/512gb/4tb SN850X
Display(s) X58222 32" 2880x1620/32"FHDTV/273E3LHSB 27" 1920x1080/6.67"/LTPO AMOLED panel FHD+120hz/7" FHD 120hz
Audio Device(s) Logi Z333/SB Audigy RX/HDMI/HDMI/Dolby Atmos/CVJ NightElf/Moondrop Chu II+BT20S/Nekocake GfL QBZ-191
VR HMD Medion Erazer
result for a 12600K
"Should be optional. 12600K is well below the maximum CPU for the socket, and you really only need the extra pins for high overclocking.
4 12V wires should be around 200W capacity before they start getting too warm for comfort. Adding in two more is just to keep the load spread out a little more."
although in my point of view, i would still connect both, but you would be fine with the 8pin alone, i guess
3,195 (2.27/day)
Motherboard Apple proprietary
Cooling Apple proprietary
Case Apple proprietary
Mouse Apple Magic Trackpad 2
Software macOS Sonoma 14.7
The frequently parroted advice is if you aren’t doing extreme overclocking to your CPU the 8-pin cable is sufficient.
I have both 8-pin and optional 4-pin cables plugged in on a B550 mobo driving a Ryzen 5800X mostly so I never have to think about it again. The CPU will only draw the power it needs anyhow.
4,912 (2.76/day)
System Name Mean machine
Processor AMD 6900HS
Memory 2x16 GB 4800C40
1 8pin can supply up to 360 watts or something along those lines. Unless you are using LN2 canisters to cool your CPU, you are fine
ir_cow
5,022 (0.83/day)
USA
Here I am pulling 330 from a single 8Pin EPS on a Z690 ITX :) single is fine.
Since both share the same power plane, the second is just to provide more power (if needed). Officially I don't know what the rating is, but you can just do the math for a cable. 4x 12v using 18 AWG wire (6 AMP), you get 288 watts. That is on the low side (super safe). Higher end power supplies use 16AWG and say 10 AMP would put a single cable at 480 watts on the high side.
Edit: Technically it's the path of least resistance. Meaning both cables will be in use and sharing the load.
649 (0.11/day)
Interesting inputs, people. So then it doesn't matter/won't do any harm if i connect both, huh? If it doesn't matter/doesn't do any harm, then i'll do that. :)
3,195 (2.27/day)
If plugging in both CPU power cables was dangerous, it would probably be mentioned in the owner’s manual.
You do RTFM, yes?
In fact, there would probably be some sort of obnoxiously bright colored protective sticker on the 4-pin EPS connector from the PSU manufacturer as well Klaxoning imminent destruction to prevent illiterate slobs from burning the neighborhood down.
:):p:D
18,584 (2.63/day)
System Name AlderLake
I used 2 cables for the CPU on my Z690 Aorus Master, just because I could.
382 (0.24/day)
System Name Incomplete thing 1.0
Processor Ryzen 2600
Motherboard B450 Aorus Elite
Cooling Gelid Phantom Black
Memory HyperX Fury RGB 3200 CL16 16GB
Video Card(s) Gigabyte 2060 Gaming OC PRO
Storage Dual 1TB 970evo
Display(s) AOC G2U 1440p 144hz, HP e232
Case CM mb511 RGB
Audio Device(s) Reloop ADM-4
Power Supply Sharkoon WPM-600
Mouse G502 Hero
Keyboard Sharkoon SGK3 Blue
Software W10 Pro
Benchmark Scores 2-5% over stock scores
What you find easier or better looking, if you aren't doing anything extreme with it. Personally I would plug in one, knowing it's less cable mess, and don't even see it with my AIO.
649 (0.11/day)
Yes, that is true; i won't be doing anything extreme. My field of use: live streaming, streaming multiple events, video editing + rendering, web designing, casual gaming and multi-browsing. Ok, so plugging in 1 then. Thanks for the input!
sneekypeet
not-so supermod
29,711 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
I plug em in for looks above usefulness.
It's there, I got the cables, why not?
Toothless
Tech, Games, and TPU!
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Ya paid for all the cables, so use all the cables. Remember; cables get lonely in boxes too.
