quick question about a device, it ends soon on ebay so i need a qick answer please
3,629 (0.59/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
Just note that those only support SATA I (1.5GBs), if your drive is SATA II (3.0GBs) you will need a different card, or default to SATA I speeds.
its just says sata on the hdd so im guessing its just sata1?
I believe so.
Technically its SATA 1.5Gb/s and 3.0Gb/s.
Anyways, there are hardly much advantage in terms of performance since HDD can't reach SATA speed sustained.
its a VIA chipset on the card, they have shit drivers.
I've got two similar cards here in the spare parts that wont work in vista/7 x64 - they just refuse to initialise, even when they have 'supported' drivers.
ok guys thanks for that i went for the one viper suggested it was a little cheaper. Im only using xp 32 so no problems there and performance wise i couldnt care as long as its reliable
