Quick Question: Dual Channel memory on AM2(+)
739 (0.10/day)
Austin, TX
System Name WAZAAM!
Processor AMD Ryzen 3900x
Motherboard ASRock Fatal1ty X370 Pro Gaming
Cooling Kraken x62
Memory G.Skill 16GB 3200 MHz
Video Card(s) EVGA GeForce GTX 1070 8GB SC
Storage Micron 9200 Max
Display(s) Samsung 49" 5120x1440 120hz
Case Corsair 600D
Audio Device(s) Onboard - Bose Companion 2 Speakers
Power Supply CORSAIR Professional Series HX850
Keyboard Corsair K95 RGB
Quick Question:
What are the requirements for running dual channel? Only two sticks? or symmetrical sticks across the channels?
Can you run 4 sticks (symmetrical) in dual channel?
Right now, I've got 2x2GB, can I add 2x4GB and still run in dual channel? (ignore the fact that my board only supports 8GB, it's completely hypothetical)
Generally it's having the same amount of RAM (at teh same speed) in each channel. Refer to your motherboard's manual to see which slots are for which channel :)
As Darknova said, and to explain it easier.
At the memory slots on your mobo there should be 2 colours, colour 1 (say, black) is the A slots, meanwhile colour 2 (say, orange) is he B slots.
Black slot A1 [2GB -@800mhz 5-5-5-15] | Orange Slot B1 [4GB@800mhz - 6-6-6-18] | Black slot A2 [2GB@800mhz - 5-5-5-15] | Orange slot B2 [4GB@800mhz 6-6-6-18] <--- there you got dual channel well built xD
Mem speed will be the slowest you have, if you have 2 sticks DDR2 1066 and 2 sticks DDR2 800, all four will run at 800mhz
Generally, A slots and B slots are independent, you can have 10 GB on A slots and 256MB on B slots... As long as clocks are the same, it'll run fine :D
My 2 cents :D Ale:rockout:
It feels so good to be baaaaaaaack! :toast:
