quicktime showing question mark ?
freaksavior
To infinity ... and beyond!
8,095 (1.19/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
yup, since i got my 24" i've been trying to play 1080p content and i can't stream anything from apple's site so does anybody know why i keep getting this?
Mmm Google:
WWW FAQs: Why do I see a blue QuickTime question mark instead of Flash movies?
2007-11-05: You are seeing a blue question mark and a QuickTime logo on lots of websites. The contents should be playing in Macromedia Flash Player, but you see an error message from QuickTime instead. What's the problem?
You have Apple's QuickTime player software. Recent versions of Apple's QuickTime player software sometimes consider themselves to be the official player for Flash file formats as well. Unfortunately, they can't actually handle some Flash files. So you see the question mark... And no useful error message! Way to go, Apple.
Ouch! Can we fix it?
On Windows, yes— there is a simple fix which I will describe below.
On MacOS X, a similar series of steps usually does the job just as well.
How To Solve The Problem On Windows
Just follow these steps (for Windows— see below for the Mac):
1. Click the "Start" menu
2. Double-click "Control Panel"
3. Double-click the "QuickTime" icon
4. Select the "File Types" tab
5. Click the "+" sign to the left of "Miscellaneous"
6. Make sure "Flash media" is NOT checked
7. Click "OK"
8. Close the control panel
9. Restart your web browser (don't just refresh the page, exit Internet Explorer, Firefox or whichever browser you use and start it again).
How To Solve The Problem On MacOS X
1. Go to the Apple menu
2. Select "System Preferences"
3. Select "QuickTime"
4. Select the "Advanced" tab
5. Select "MIME Settings"
6. Select "Miscellaneous" and uncheck the "Flash" option.
7. Restart your web browser (don't just refresh the page, exit Safari, Firefox or whichever browser you use and start it again).
Flash movies should now play in the correct player, or invite you to download Flash Player if you don't already have it.
If you still see the blue question mark icon for a certain file, there's always the possibility that it really is a defective QuickTime file— the website's fault, not your computer's fault. In this case there's nothing you can do on your own computer to fix it. Complain (politely, please) to the owners of the page in question.
I have googled it. i couldn't find what i needed, and yes, i tried that.
i just got it. i updated flash.
