R7 250 1GB GDDR5
rakionero1993
13 (0.01/day)
Hello people, I need help with my video card, I have a R7 250 1GB GDDR5 and my mother is a (H61M-VS) and when I install the video card, it does not give me an image, but the fan works .... Does anyone know why?
I have i5-2500 3.30ghz
8GB ram
I would appreciate your help please.
847 (0.34/day)
Haswell, USA
System Name Bruh
Processor 10700K 5.3Ghz 1.35v| i7 7920HQ 3.6Ghz -180Mv |
Motherboard Z490 TUF Wifi | Apple QMS180 |
Cooling EVGA 360MM | Laptop HS |
Memory DDR4 32GB 3600Mhz CL16 | LPDDR3 16GB 2133Mhz CL20 |
Video Card(s) Asus ROG Strix 3080 (2100Mhz/18Ghz)|Radeon Pro 560 (1150Mhz/1655Mhz)|
Storage Many SSDs, ~24TB HDD/8TB SSD
Display(s) S2719DGF, HP Z27i, Z24n| 1800P 15.4" + ZR30W + iPad Pro 10.5 2017
Case NR600 | MBP 2017 15" Silver | MSI GE62VR | Elite 120 Advanced
Audio Device(s) Lol imagine caring about audio
Power Supply 850GQ | Apple 87W USB-C |
Mouse Whatever I have on hand + trackpads (Lanchead TE)
Keyboard HyperX Origins Alloy idk
Software W10 20H2|W10 1903 LTSC/MacOS 11
Benchmark Scores No.
Do you have UEFI enabled? I remember later gen AMD cards having issues with legacy systems
rakionero1993
13 (0.01/day)
I should look at the options
I'll be right back
Restart the computer, and I do not know what UEFI is, but the F2 option that said UEFI, I touch f2, and I take the options of the mother, but I do not know what you wanted to say if I have it activated or not? If you could give me a better explanation I would really appreciate it.
44,269 (6.80/day)
8GB ram
What revision of the motherboard do you have?
take the side of case off and take a picture of the White Silk Screen, it should be in the middle of the motherboard between the cpu and northbridge or between the northbridge and first pcie slot.
Being a core i 2000 series it is most likely your motherboards bios is out of date for the gpu.
rakionero1993
13 (0.01/day)
Hello my friend, i really thank you for try to help me.... here have a picture.
and another one
44,269 (6.80/day)
and another one
Ok that shows chipset revision, not info needed. Please re-read my previous message and do that in order to receive proper help. I need the exact motherboard revision you have.
rakionero1993
13 (0.01/day)
Well i don´t know english i use google traslator, here.
44,269 (6.80/day)
Ok i believe your board is revision 1.02 so lets see, give me a moment
44,269 (6.80/day)
rakionero1993
13 (0.01/day)
Ok listen up.
There is no guarantee this bios will help as it is from 2012, but flash it please with a working monitor so you can see what is going on.
After that flash please plug the card in and see if you can get your monitor to boot from the r7 video card.
If not please let us know.
I thank you very much for your help, but I just fixed something interesting.
That pci-express 2.0 is also 3.0, but says that for it to work with express 3.0 video cards, I need a third generation i5 or i7
MY I5 is 2500 second generation
44,269 (6.80/day)
No you do not. I have a pcie 3.0 card in a pcie 2.0 motherboard.
Your bios on the motherboard needs a update and it is possible your R7 video card needs a CSM(Legacy) bios to work. Please flash the motherboard bios and let me know if the r7 card now works or not after the motherboard bios is flashed.
rakionero1993
13 (0.01/day)
Ok ok ok, in a while or tomorrow I notice how everything went, because now I do not have any USB to update the bios, I really thank you for your heart, for trying to help me and ask for pictures of my motherboard. I hope everything works correctly and can play the resident evil 2 remake with low graphics.
14,541 (3.79/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
The R7 250 is an early card and should be legacy and UEFI capable, the Motherboard having the updated B3 chipset should also not have an issue with that card.
Test the card in another system to test that it still works.
rakionero1993
13 (0.01/day)
Yes, the r7 250 video card works perfectly on my brother's computer, the only problem is me n.n
14,541 (3.79/day)
Sunshine Coast
Memory 32 GB DDR4
Mouse Lenovo
First picture shows the Motherboard supports UEFI GPU's out of the box.
8GB ram
Did you have a previous video card in that system, where all Discrete display drivers removed with DDU?
rakionero1993
13 (0.01/day)
Yes but, it must be because I have outdated bios
Yes i have it gt 240 1gb ddr3, but i unnistall the drivers from the Nvidia But I did this like 7 hours ago xDD
2,207 (0.76/day)
I have two Radeon R7 240 2GB & 4GB version, both working on motherboard 939. I use these cards "for testing purpose only" as I don't want to plug/unplug my expensive card.
Anyone that do a lots of testing of CPUs only, I strongly recommend these GFX cards if you can find them cheap. One of my cards cost less than 20 USD & it works with the latest AMD drivers.
Advantage: No messing around with extra power cord.
rakionero1993
13 (0.01/day)
Thanks for everything eidairaman1
They were the bios and finally I could install the drivers and play :D, I thank you for a lot of heart
