- Jan 14, 2016
- 141 (0.04/day)
- Winnipeg, Canada
System Name | I overclock AMD setups |
Processor | AMD 8320+ @ 4.95GHZ / AMD 6300 @ 4.8 Ghz / AMD 8350 @ In RMA |
Motherboard | Gigabyte 990FXA-UD3 / Gigabyte 970-D3P |
Cooling | Corsair H100 |
Memory | 16GB DDR3 Corsair Vengace |
Video Card(s) | MSI GAMING GTX 980 @ 1545Mhz core |
Storage | Samsung SSD 850 EVO 250GB |
Display(s) | Acer 144hz |
Case | Coolermaster CM 690 III (White Version) |
Audio Device(s) | Creative Titanium Fatality Pro |
Power Supply | Corsair Hx750i |
Mouse | Logitech G300s |
Keyboard | Microsoft Digital Media |
Software | Windows 10 64 |
Benchmark Scores | 23.0k on Skydiver, 8.1k on Firestrike. 1.5k single, 9.7k multi CPU-Z |
Hello everyone. It looks like my XFX R9 380 has developed coil whine. At least I think it's coil whine. This noise is slightly lower pitch than a whine and begins when the card is under heavy load, and high FPS.
I have tried a few things to cut the noise; Using a frame limiter, using V-sync, lowering clock speeds, and lowering settings. These all worked a bit, but I don't like to limit my frames low as I use a 144hz monitor, and I don't like the input lag of V-sync.
Should I bother RMAing this card? It works great and overclocks like a champ. I would rather not go through the trouble if it is just in fact a noise issue. Anyone else experienced noise with this series?
