hi everyone.
just joined in hope that someone may be able to help me.
i recently installed a radeon 6970 into my computer and it worked fine, no problems at all for the first day. On the second day the pc rebooted itself as soon as the desktop screen appeared and then worked fine after rebooting. Same thing happened hours later when i returned from work. The problem got worse over a week to the point where my pc would get stuck in a loop, constantly rebooting only to crash again at the desktop screen. Safemode does not work either, Its reboots while loading the drivers. This problem only starts after the graphic cards drivers have been installed. I RMA'd the card whilst re installing my previous card (radeon 4890). My pc worked fine no problems at all. Got a email from overclockers saying they found no problems with my card so i installed it into my brothers computer along with my power supply. It worked fine, no problems at all over 3 days.I reinstalled the 6970 and I tried resetting the bios on my motherboard and to my suprise it worked fine but the clock speed on my RAM was 1066mhz instead of 1600mhz. After a few days i put the clock speeds of my RAM back up to 1600mhz but then the rebooting started again. I have tried only using 6gb instead of 12gb and trying the card into a different pci slot. I have tried increasing the voltage to the card and RAM and still having no luck. Not sure what else i can try.
Any advice would be appreciated
thanks
system specs:
Intel Core i7 920@ 2.66Ghz
Gigabyte X58A-UD3R
Radeon HD 6970
Kingston HyperX 12gb @ 1600mhz
Windows 7 64bit
Corsair 850w psu
thanks
system specs:
Gigabyte X58A-UD3R
Radeon HD 6970
Windows 7 64bit
Corsair 850w psu
