Raid 0 with two different hard drives?
369 (0.05/day)
Processor 7700 Kaby "baeby" @ 4.5 Ghz
Motherboard ASUS MAXIMUS FORMULA IX
Cooling Corsair H100i
Memory 16 GB
Video Card(s) EVGA 980 Ti SC+
Storage EVO 512 gb
Display(s) 240 Hz
Case ANTEC Twelve Hundred
Power Supply EVGA 1300 Supernova
Mouse Coolermaster Master Mouse MM710
Keyboard Steelseries 6gv2
Benchmark Scores Higher than the Light of Revanchist
Hey guys, I bought a WD Caviar black 1TB and want to Raid 0 with my WD Caviar Green 1 TB and am wondering will it be safe? From what I have heard the Green is at 5400 RPM and goes up to the Blacks speed when use, it is more "eco-friendly" per se.
Also, when I raid 0 do I lose all my files??
thank you
peter
You can raid the two drives, but it is not recommended because of the speed differences.
If you raid-0 then if a drive fails all your data is lost. Raid 0 offer higher read and write speeds.
Yeah don't worry about RAID0 those drives together. That would be a waste of a Caviar Black. Instead put Windows, Apps & Games on the Black and just use the Green for incoming/working data, mass data storage and backup purposes.
thank you for all your fast responses.. So dont Raid 0 them?? they are almost alike though arent they?
edit,, would you say system programd and windows on black or games on black?
also freak,, on idle the green runs at 5400 rpm but goes up to 7200 when in use so i think they are almost alike more or less
You could, but it would be pointless,
The idea of raid is to have identical drives to write data across multiple drives, then it will read from both at the same time, and having faster access time. The green drive will be variable rpm while the black is a constant 7200rpm. if your die hard set on raid, sell one of them.
this is an interesting subject. hey i f you have the time. use a short install OS and do a HDtune test with them normal and a test with them in raid 0 for kicks
can someone please help me to figure out why i cant RAID 0 my 3 HDDs? :roll:
Situation:
using 2 equal disks,
WDC WD800BD
WDC WD800BD
and
WDC WD800JD
I can create RAID 0 array but windows cant see it when im trying to install.
allready checked sata ports compatibility, switched betwen them whitout success.
thank you:toast:
hmmm sounds like that one odd ball drive is messing things up. maybe you can sale all those and order 3 or 4 exact drives
vnl7:
Does Windows see it when it's just the first two drives in RAID0?
What version of Windows is it? XP needs RAID drivers for most systems.
Yes, it only works whit
WDC WD800BD
WDC WD800BD
if a use any type of RAID whit WDC WD800JD it does not work.
Strange that i used this RAID 0 setup (WDC WD800BD + WDC WD800JD) on my old nforce 2 and worked.
That's odd and interesting. When you're booting up, it does say that the three drives are in a RAID array, correct? I mean you can verify that they all have for sure been successfully added to an array? Use something like an Ubuntu LiveCD (or Acronis boot disc) to double check if it can see the array.
That's odd and interesting. When you're booting up, it does say that the three drives are in a RAID array, correct? I mean you can verify that they all have for sure been successfully added to an array? Use something like an Ubuntu LiveCD to double check if it can see the array.
Array successfully added but no windows or linux cant see it.
One other thing is that i can raid 5 these 3 disks but after the first reboot during the installation i shows RAID ERROR but i cant finish the installation.
I tryied to add a disk on a working RAID 0 in windows, after the process i reboot windows and get RAID ERROR again, and cant boot windows anymore.
watch out. WD implemented some sort of software into their drives that causes green drives to fail in RAID...
newegg reviews definently indicate that if you do not have a wd raid edition drive, you have a very high chance of failure with a green drive, since they power down periodically to save energy, and cause the raid controllor to drop the drive from the array.
check this thread: "http://www.tomshardware.com/forum/251076-32-raid-issues-western-digital-hard-disk"
edit:
Nordic pc explains this better:
"Also, and very importantly, this drive is not for RAID systems. To keep with the low-power design, Western Digital chose to automatically park the drive heads at times, which some RAID systems will see as a hard drive failure. So you could be in a constant RAID rebuild if the drives are mirrored, or if the drives are in RAID-5 for parity, you could lose all of your data. WD has acknowledged this, and released the RE4-GP 2TB hard drive for users who need big RAID arrays. They are really pricey though, so you may want to stick with a 1TB Caviar Black for your RAID solutions."
(http://www.nordic-pc.com/node/422)
I like your post man. Before this I had heard reassurances that Green drives did indeed work fine in RAID0. It's good to see more sources stating that they definitely don't play well in RAID0.
