- Feb 22, 2010
- 227 (0.04/day)
- Kent, UK
System Name | Cannon |
Processor | Intel Core i7 13700K |
Motherboard | Asus Z690-P D4 |
Cooling | Corsair H100i PRO XT w/ Corsair ML120 White LED x2 |
Memory | 32GB (4x8GB) Corsair Vengeance Pro RGB 3600MHz |
Video Card(s) | Palit RTX 3060 Ti Dual 8GB |
Storage | 1TB 980 Pro w/Heatsink + 500GB 970 Evo Plus NVMe + 2TB MX500 + 500GB 850 Evo |
Display(s) | 34” Dell S3422DWG 3440x1440 144hz Curved + 27" Dell U2713H IPS 1440p + Dell P2219H IPS 1080p |
Case | Corsair 4000X RGB - 3xSP120 ELITE RGB (Front Intake) + 1xML120 White LED (Rear Exhaust) |
Audio Device(s) | Creative Sound Blaster Z SE + Logitech z623 2.1 |
Power Supply | Corsair RM850x SHIFT |
Mouse | Logitech G602 |
Keyboard | Corsair K70 RGB |
VR HMD | Oculus Quest 2 |
Software | Windows 11 Pro x64 || Linux Mint |
Benchmark Scores | None. Primary uses are browsing, music, gaming (mostly Battlefield & Doom) and virtualization! |
Greetings all,
As per system specs, I have a 2x8GB set of Corsair Vengeance RGB PRO DDR4 3600Mhz ( CMW16GX4M2D3600C18 ) ordered from Amazon late last year.
I recently ordered a 2nd set from the same link/model number but received a different revision. I chose not to install as understood that different revisions use different NAND from different manufacturers and had compatibility concerns - I know it should technically work but would rather match as best possible.
So I contacted Amazon who dispatched a replacement (on condition of returning existing set by March) however, they were unable to confirm which revision could be sent as SKU is the same, so I received yet another revision.
Currently I have all 3 sets, but one set of the newer ones will need to go back.
Currently installed RAM is rev. 3.34, 2nd order is rev 5.32 and replacement delivery is rev. 8.31.
I've got to keep the 3.34 DIMMs as I've already been using those several months, but rev5.32 and rev8.31 are unopened so I can send either back.
Reading up on this, I found the following: Die versions etc - Memory - Corsair Community
"The numbers take the for "ver X.YZ" where;
* X is IC maker - 3 for Micron, 4 for Samsung, 5 for Hynix, presumably 8 for Nanya as with DDR3
* Y seems to be capacity per rank - 1 for 2GB, 2 for 4GB, 3 for 8GB. Usually this translates directly to IC density (8GB/rank = 8Gbit), but ver 4.14 which uses half as many double width "x16" 4Gbit chips is a special case.
* Z is revision, usually starting from A=0 and usually counting up one letter per increment. Hynix's first revisions are lettered "M" which is numbered as X.Y9, samsung now do this too and it will proesumably be the same.
The known and possible version numbers are as follows;
Version Vendor IC Confirmation?
3.20 Micron 4Gbit Rev.A Presumed
3.21 Micron 4Gbit Rev.B Confirmed
3.22 Micron 4Gbit Rev.E* Speculated
3.22 Micron 4Gbit Rev.F* Confirmed
3.31 Micron 8Gbit Rev.B Confirmed
3.33 Micron 8Gbit Rev.D Presumed
3.34 Micron 8Gbit Rev.E Speculated
4.14 Samsung 4Gbit D-die (4x16) Confirmed
4.23 Samsung 4Gbit D-die Confirmed
4.24 Samsung 4Gbit E-die Confirmed
4.31 Samsung 8Gbit B-die Confirmed
4.49 Samsung 16Gbit M-die Speculated
4.40 Samsung 16Gbit A-die Speculated
5.29 Hynix 4Gbit MFR Confirmed
5.20 Hynix 4Gbit AFR Confirmed
5.21 Hynix 4Gbit BJR Speculated
5.39 Hynix 8Gbit MFR Confirmed
5.30 Hynix 8Gbit AFR Presumed
5.31 Hynix 8Gbit "BFR"??? Speculated
5.32 Hynix 8Gbit CJR Presumed
8.20** Nanya 4Gbit Rev.A Speculated
8.30** Nanya 8Gbit Rev.A Speculated"
(Copied from source at Die versions etc - Memory - Corsair Community)
Any suggestions or thoughts on what might be best to do? Which out of the 5.32 or 8.31 revs are likely to be the best "fit" with existing 3.34 DIMMs? Reluctant to return both and play the revision lottery again...
