Ram usability question
168 (0.10/day)
System Name MonsterBot
Processor AMD FX 6350
Motherboard ASUS 970 Pro Gaming/AURA
Cooling 280 mm EVGA AIO
Memory 2x8GB Ripjaw Savge X 2133
Video Card(s) MSI Radeon 29 270x OC
Storage 4 500 gb HDD
Display(s) 2, one big one little
Case nighthawk 117 with 5 140mm fans and a 120
Audio Device(s) crappy at best
Power Supply 1500 W Silverstone PSU
Mouse Razer NAGA 2014 left handed edition
Keyboard Redragon
Software Win 10
Benchmark Scores none
Specs are in Sig.
I noticed for the first time today when I was looking at my system specs that it recognizes there are 16Gb RAM but only 7.75 are usable.
I don't think I had one go bad as I ran a mem test maybe 6 months ago.
I have 2x8Gb, would I be better suited for 4x2GB?
Why in the capitol eff would it have 4 slots on the MOBO and only be able to use only 8 Gb? It is an old board, maybe I didn't notice when I bought it, I am sure I have looked at the system specs before and never noticed or something.
Either way I am ... disappointed...
Check how much is reserved for the system.
I guess I don't know how...
Device name MonsterBot
Processor AMD FX(tm)-6350 Six-Core Processor 3.90 GHz
Installed RAM 16.0 GB (7.74 GB usable)
Device ID 8EE498B4-55AF-46EE-ABF7-0E32E06F8A7F
Product ID 00326-00857-89587-AAOEM
System type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
This is what comes up under 'about'.
Open up Task Manager ( Ctrl, Alt and Del keys all at once) once it's open select the Performance Tab then go down to Memory and it will display all the info there.
In use, available, committed and cached.
Bam.
Whats it mean?
Run memtest 86+ see if it can see all the ram
Or you know the bios idk why im a dumbass
check that memtest can see all you RAM
Check your bios doesn't have onboard video enabled, and while you're there change the memory clock down a notch (like from 2133 to 1866) and reboot. If windows sees the full amount go back to bios and set it at the faster speed again.
If your motherboard is indeed the ASUS 970 Pro Gaming/AURA from your specs then make sure the RAM is installed in the correct slots... according to the manual recommended position is slots 2 and 4 counting from the CPU socket so it should be CPU > empty > RAM > empty > RAM
Also according to the specs 8GB should be fine, 2133MHz is mentioned in the specs but you could try turning off any XMP etc. and see if that helps any.
I had to check, but I have them as described. Thats a good way to put it A1 and B1 are a little confusing since they are not marked on the board that I saw.
I totally took my overclock off when I uninstalled all of my games. No XMP no nothing
Now it's just a glorified T.V. :cry:
I have the VGA cable plugged directly into the GPU. Can you explain how the on board video system would screw with me? I don't understand.
I just looked it up, AMD 970 doesn't have any onboard video. This motherboard doesn't even have a video output connector. I think it's really strange that Windows is seeing 16GB of DDR3 but basically 8GB is being reserved. I would restore BIOS to defaults and go from there. If that doesn't make a difference, if you have a spare disk or don't care about the Windows install or disk contents install a fresh copy of Windows and see if that fixes it. You could also try the refresh install option but that doesn't always fix the problems.
Google showed me this:
How to change hardware reserved memory?
What To Try
  1. Click Start , type msconfig in the Search programs and files box, and then click msconfig in the Programs list.
  2. In the System Configuration window, click Advanced options on the Boot tab.
  3. Click to clear the Maximum memory check box, and then click OK.
  4. Restart the computer.
