Razer Sphex V2
Deathhated
10 (0.00/day)
I currently have the Razer Sphex V2 and it doesn't stick much anymore because of dust on the adhesive base. I just wanted to ask if there is any other way to clean this pad and have it stick again, like when it was newly bought. Thanks for the helps in advance
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
Although I could Google it ,I would encourage you to explain what that is ,to make assisting you easier. If only for those of us who arent familiar with that particular item, from your description i can infer its some type of sticky pad ?
Edit
It appears to be a adhesive "go fast" mouse pad.
Reactivating dried up adhesives is extremely difficult in some cases, your best bet might be to find an alternate solution . Something like using Velcro adhesive, or non-skid padding, etc.
Deathhated
10 (0.00/day)
Edit
I'm not sure it's "reactivating" the adhesive part, but cleaning it. Dust has built up, preventing the adhesive base to stick or make contact with the table
44,274 (6.80/day)
