- Aug 9, 2024
- 58 (0.19/day)
Processor | i5 13400F |
Motherboard | Asus Z790 Prime D4 |
Cooling | DeepCool 120MM |
Memory | 32GB Corsair 3200Mhz CL16 |
Video Card(s) | Gigabyte RTX 3070 |
Storage | Samsung 980 Pro |
Display(s) | LG UltraGear 24 165hz |
Case | DeepCool |
Power Supply | CoolerMaster 750W Gold |
Mouse | Logitech G305 |
Hi, I have Razer Blackshark V2 and i'm using Windows 11
i'd never had any issue with the Razer Synaps till now. but since yesterday ( I changed my Windows ) the razer Synaps and even i'v tried Razer Synaps BETA but both of them have weird bug.
Synaps Orginal:
the Audio is all of my application is set to 100 even if I try to lower it to 30 40 50 it's not working and it's always on 100%, the only time it Gets low is when I change the volume in the app to 0! for example in the VLC Media Player this bug wont let me change the volume of the clip and it's on 100% all the time.
another weird bug that I faced is the Audio Voulme Jump, when ever I'm Playing something that has audio( CLIP, Music, YT and... ) for a second the volume boosts and then it drops to the normal volume.
Synaps BETA:
none of the issue that I mentioned above are here but when I try to stream my screen in a App Like Discord, everyone in my Live can hear a Click going throw there left ear or right.
i had none of this issue before but my friend had the problem that I have with the Synaps BETA but on the Original Version of the Software !
is everyone having the same issue? why not Razer Do anything after like 5 month! like it's only me and my friend that having this issue and he had got it earlier than me.
i tried uninstalling Synaps with iObit Uninstaller ( to remove the files deeply ) and then install the BETA Version and Versa... but none Worked.
Synaps Orginal:
Synaps BETA:
