Reallocated event count warning and power on count at 267 billion hours
Tom26
3 (0.00/day)
My ntbtlog.txt showed a lot of "Did not load driver.." so I tested my HD with HD Tune Pro.
I'm getting some weird readings. Note the Reallocated event count and the power on hours count.
I also don't remeber making 25k unsafe shutdowns.
Weird also is that Hard Disk Sentinel does not show this.
I'm running windows 7 64bit on a 3.5 year old Lenovo Thinkpad X201i. i3 2.67gh. 6gb RAM
I'm currently backing up everything just to be sure, but does this mean it is slowly failing on me?
Thanks in advance,
Tom
Mind running crystal disk info instead? Slightly plainer and to the point, it will tell you if you should be looking at replacement
@SuperSoph_WD could offer advice
...or AIDA64. AIDA has a good SMART tool that can scan through RAID devices as well.
Side note: Make sure all your SATA cables are secure. This issue smells strange.
That doesn't look like a WD model number but rather a Seagate.
Its a laptop. So i guess that cancels out checking the cables.
AIDA64 seems so say its all fine.
As does CrystalDiskInfo. That bell scared the cr@p out of me..
Maybe HD Tune PRo is giving bogus readings?
The numbers rise dramatically every time i press update...
All software is giving the same readings of reallocated event count. Obviously one piece of software sees it as an issue whereas the rest don't. One of your drives has a warning though.
I'm aware of that one. It failed me once. Got my data off, backed it up so its function is a second backup now.
Cool, guess my laptops HD is fine then...
well i wouldn't go that far. the value is not 0 its 88 the other programs just have a different tolerance for what is bad.
actually that may be normal for that drive. it looks like maybe its just an issue with that program.
