Realtek HD driver installation Error 0xE000024B
Loutre Suprême
2 (0.00/day)
Hi.
First, i'm sorry for my bad english.
I had custom driver from @AAF Optimus to work with my surround.
I used realtek HD drivers 6.0.1.8158 with X-Fi MB5 and it was perfect. Every games was working in 5.1.
For some problem i had to try to update my audio drivers
I made a backup before.
But when i try to reinstall my driver backup, windows delet it .
Then i unzip my old custom drivers and try to reinstall them manually but it's impossible .
Always this.
Even if i delete drivers, use driver store Explorer to delete all realtek and AAF things, nothing work.
I can't find again the place where it was explain how to install this driver.
I try with new AAF drivers but DTS do not work and i have ugly bass.
Does anyone can help me please ?
Thanks !
I
kqlandia
18 (0.01/day)
Hello you speak Spanish? I tell you, that the most appropriate thing for that is that you uninstall first with the DDU uninstaller driver the driver of realtek and / or any other sound card that you may be using (if possible) and then try again, failing that if that does not work you will have to use another audio pack that by the way there are many. The AAFHDAdvanceAudio 6.0.8960.1 is good and can serve you, it has soundblaster connect 2, ATMOS, nahimic 3, and enables dts/ddl in the spdif output, without problems
Ahhzz
Super Moderator
9,193 (1.47/day)
System Name OrangeHaze / Silence
Processor i7-13700KF / i5-10400 /
Motherboard ROG STRIX Z690-E / MSI Z490 A-Pro Motherboard
Cooling Corsair H75 / TT ToughAir 510
Memory 64Gb GSkill Trident Z5 / 32GB Team Dark Za 3600
Video Card(s) Palit GeForce RTX 2070 / Sapphire R9 290 Vapor-X 4Gb
Storage Hynix Plat P41 2Tb\Samsung MZVL21 1Tb / Samsung 980 Pro 1Tb
Display(s) 22" Dell Wide/24" Asus
Case Lian Li PC-101 ATX custom mod / Antec Lanboy Air Black & Blue
Audio Device(s) SB Audigy 7.1
Power Supply Corsair Enthusiast TX750
Mouse Logitech G502 Lightspeed Wireless / Logitech G502 Proteus Spectrum
Keyboard K68 RGB — CHERRY® MX Red
Software Win10 Pro \ RIP:Win 7 Ult 64 bit
Hi there :) This is an English-speaking forums, and we're going to need you to post in English, please. Thank you !
